powershot1
for an APEX LTX GT with MPI Stage one Supercharger??
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Innovate, FJO, AEM would all work well based on the feedback here in the turbo/sc forum.
I run the Innovate LC-1 with a XD-16 gauge and I'm very happy with it. It is also the most accurate of the meters according to lab tests, but they all have their strong sides, FJO is very well built and comes with a lifetime warranty and it will also take the NTK sensors which will withstand the abuse of running leaded race fuel much better than the inexpensive bosch sensor most other systems run.
I had the innovate and couldn't make it be consistant. Some say it is wiring others couldn't make theirs work either, I switched to FJO and a NTK sensor for leaded fuel use, and not as tempermental. But The Innovate has been proven to be the best.
T-Nytro
Has nothing but troubles with Innovative. Went through sensors like crazy. Switched to AEM, and after 2500kms still good and working great. I would go with AEM.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
No problems in 2 seasons and 7000+ kms
925rotax
my buddies all run aem, i just installed mine
925rotax
turbonater has a used one for sale
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
On my RX-1mtn with the MPI stage 1 SC; I run the Daytona multifunction gauge for my temps and rpms and the WMS A/F gauge. I bought both from MPI when I ordered the SC almost three years ago (will be 3 yrs in Nov.). Both have done great; only problem is I lost my O2 sensor due to leaded fuels usage early last season (ocaisionally it still works). Here's a picture of my gauges.
Jim
Jim
TurboJamie
I was eating sensors with the Innovative too switched to AEM and no problems since. The WMS unit MPI sells is ok too but I also ate 2 sensors with it.
925rotax said:turbonater has a used one for sale
Which brand?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Gotta add that I run on premium pump gas. I mix up some unleaded racefuel from time to time when racing on the lake with my friends, gotta have the ability to turn the boost up if needed, hahaha
Did you guys run leaded race fuel when having problems with the Innovate. The Innovate gauge is not sealed, did it pic ut moisture on the inside of the glass. Mine does but it hasn't failed on me yet.
TurboJamie
rxrider said:Gotta add that I run on premium pump gas. I mix up some unleaded racefuel from time to time when racing on the lake with my friends, gotta have the ability to turn the boost up if needed, hahaha
pump gas here
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I'm gonna be the oddball here, as usual. I run all Autometer gauges. ( C2 Series ) Here's a pic of mine. Has been great and durable. Autometer has a great customer service and warranty as well. I liked the color coded dial. At speeds it is hard to read a number. My other gauges are sweep, not digital.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Troubles with innovates , (3) sent all back , have gone to FJO
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Man I gotta be the oddball too not having problems with my Innovate, mine gotta be from a good batch
