apltx08
Took a few pic's while installing them for you guys to see...I'm a litttle un-sure on how the bracket is going to hold up...will see this winter, the bearings are replaceable "6004", this YAM kit is very easy to install no drilling.
Addict
What's the cost of the kit?
apltx08
$89.95 + taxes, be careful you have a kit for 136" & 121" both have diff part # the 1 seen here is for 136"
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
nice post...thanks...
1) are those the narrow slides?
2)for my 136 skid, I want that one and one for up on the curve...any idea of that one?
also..I didnt see that in the accessories catalog...do you have different stuff in Ca?
ROCKRTX
Is this a new wheel kit for 2009?
i can't find it on yamaha site
Addict
Available in US too. Shows on Port's site
SNOW WHEEL KIT (SMA-8FT95-00-00) $67.16
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I see it now...wonder if this can be mounted in other locations (like at the curve)
ualav8
i see you mounted them on the inside of your skid. i mounted them on the outside. which way is better? from the directions, i got the impression they were outside mount.
SLEDSTART
did you guys ever determine if these should be inside or outside the rails???
Anyone know the 121" part number and why would it be different than the 136"? Should mount the same way....
FLYBYU
SNOWDOG said:did you guys ever determine if these should be inside or outside the rails???
Is that the first thing your going to buy snowdog? Port yamaha is at the show
SLEDSTART
Well...we were talking about more wheeles. What do you think about this set up? This is not what your running though is it?
FLYBYU
pretty close to it right now, just no hyfax for the grass.
SLEDSTART
oh I thought you said you had some on the limiter strap rod?
I have to get over by you some time and see that sled....
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
SNOWDOG said:Anyone know the 121" part number and why would it be different than the 136"? Should mount the same way....
This is just a guess, but it might be just the instructions that are different. The brackets have more than one set of holes so it MAY be that you need to use one location on the 121" vs the 136". Of course, I'm just guessing.
SLEDSTART
I'll find out at the show tomorrow. Yamaha...Highlands and port will be there. Someone has to know what works on these things...
Oh...I know...A DIFFERENT SKID!!!
