Hi i was wondering what you guys recomend for engine oil. I want to run yamalube but dont know if i should use synthetic oil?? thanks
Turk
Tech Advisor
Search oil. been covered about 1,239,459 times!!!
jds1000
taz1 said:Hi i was wondering what you guys recomend for engine oil. I want to run yamalube but dont know if i should use synthetic oil?? thanks
Use what Yamaha recomends. Buy a Yamaha filter for it and use the Yamaha 0-W30 semi synthetic oil. Why even consider anything else? You should be able to change your own oil for about 35-40 bucks and do it once a year.
Ok so i only have 556 miles on my sled !! Should i put synthetic in or wait?? thanks
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
wait
Skydog
You are close.... then 0w 40 M1 with a Napa Gold filter (wix)
Skydog
Skydog
Goddo
- Nov 4, 2006
- 19 miles from Lewis Hills...Oh Ya.
taz1 said:Ok so i only have 556 miles on my sled !! Should i put synthetic in or wait?? thanks
It is recommended after 500 miles. As someone alluded to above, this topic has been covered, with no real answer as to the semi-synth vs synthetic issue.
Best I can figure is that for snowmobiles, an oil should contain friction modifiers to help extend the life of the engine. Friction modifiers are used in engines that do not make use of their oil for alternate lubrication purposes (clutches etc). Yamaha's new synthetic oil has no friction modifiers because it is essentially designed for sport bikes that share lubrication.
Mobil 1 and other oils are essentially designed for use in automobiles and therefore some do contain friction modifiers.
My feeling is that if you can get an oil that has the modifiers, and is synthetic, especially at a cheaper price than yamalube, then why not go that route.
You'll get a thousand different answers. Some people really believe in following manufacturer recommendations, or supporting their dealers. I believe in bang for the buck and therefore I went with Amsoil full synthetic on my oil change. The difference in price was $5 per litre cheaper for the amsoil full synthetic, and although my sled doesn't spend very many nights outside, I'd rather have the synthetic in the colder climate.
KINS
jds1000 said:taz1 said:Buy a Yamaha filter for it and use the Yamaha 0-W30 semi synthetic oil. Why even consider anything else? You should be able to change your own oil for about 35-40 bucks and do it once a year.
It cost me over $70 for oil and filter from my dealer. I'll likely look elsewhere next year.
arteeex
From page 48 of the owner's manual:
Be sure to change the engine oil after the first 800 km (500 mi) of operation, and every 4000 km (2500 mi) thereafter or at the start of a new season, otherwise the engine will wear quickly.
The oil filter cartridge should be replaced every 20000 km (1200 mi) of operation.
Seems straight forward to me.
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
i think what you guys should be looking at for oil is yamahas new FULL SYNTHETIC OIL...0w40 part number---ysm4fs0040lt.....
i think this should be used for sure for any one that has a turbo or charger on their machine....oil and filters are cheep insurance for all machine!
cheers
cheers
ok so to get back to my question is 556 miles enough to put the synthetic in my sled or is it not broken in enough yet??? thanks guys.
LazyBastard
Leave it for longer. You're past the *critical* part of breakin, but its NOT fully broken in! Your typical north american made 2-stroke will need to be rebuilt after the first 2000 miles, your typical japanese 4-stroke will be just broken in. There's no reason to rush for the synthetic, just keep using desert oil until AT LEAST 1000 miles, but preferably around 2000+.
347strokin
arteeex said:From page 48 of the owner's manual:
How could this be a straight forward answer to this guy's question?
You aren't even answering his question.
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
I switched over to mobil 1 full synthetic right after the 500 mi with no problems yet...
arteeex
Point taken. I will speak to my people so this does not happen again, today.
