vtdownhiller
been reading alot about wiring the handwarmers in series to get more heat...Exactly, which wires am I tying together...color wise I am a little confused
grader
dont remember the colors but the power is fed into one grip, the other wire from that grip is conneceted to the wire from the second grip. the last wire from the second grip goes to ground.
vtdownhiller
I am sorry I still don't understand...hot wire form grip1 gets spliced to hot wire in grip2?
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
I didn't think the RX1/Warrior had this problem?? Thought it first started with the Apex!
vtdownhiller
When I put the bar ends on last season the grips went from warm to not so warm..
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
My 05 never had good warmers. Take the power supply and run power to both warmers. do the same with the ground side. Don't turn your warmers to full hot or the 20 amp c/w fuse will blow. I ride comfortably on 1 or 2 bars now and have never needed more than 4
vtdownhiller
feed and ground to both warmers....got it. How are they set up now?
Jakexgt
(===l -_-_---- ----_-_- l===)
l i i l
l i i l
\ l /
---l-------------- Ground
l
l
l----------- Power
Since most people are visual learners I made this. Hope it helps. I think that's how it should go. Put one wire from each grip together and then connect it to the power wire coming from your wire harness that use to be connected to just one grip. Put the other wire from each grip together and connect it to the ground wire from your wire harness that use to be connected to only one. Someone please correct me if i'm wrong.
l i i l
l i i l
\ l /
l
l
l----------- Power
Jakexgt
Wow, That did not turn out the way I typed it up. Haha. Sorry guys.
vtdownhiller
the explanation makes good sense...thanks
