RocketRollinSX
- Oct 14, 2003
- Lewiston, Maine
- www.hillsidefamilyriders.com
Well, I finally got my temp gauge installed Saturday morning. Took my time and everything went fine. All my wiring was fine the first time around. Spliced the two hot wires from the gauge and went to the blue/white wire in the fuse block. Took the two ground wires from the gauge and went to a bolt on the frame. I soldered a wire directly onto the Tee itself and went to the same bolt that I used for the ground for the gauge. Fired the sled up and the guage worked right away. Here are some pics of the install.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Very nice! I have a question though. Why did you solder in the two pipes on each end? The clamps are on the Tee. The pipes don't look like they where needed and would reduce the opening size.
GreenMtnRx1
Looks great, but sometimes you don't want to know how hot your running it could scare you.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Looks Good, but you're missing a carb
RocketRollinSX
- Oct 14, 2003
- Lewiston, Maine
I soldered the extra pieces because for some reason I didnt feel safe with the hose just over the ends of the Tee. Probably didnt need them but I feel safer now. When I first bought the sled I said I wasnt going to do any mods....seems like the list gets longer and longer by the day.
Great Job!!!! I would like to add this to the TY Tech area...what do you think???
RocketRollinSX
- Oct 14, 2003
- Lewiston, Maine
Sounds good to me. If you want I can write up a more detailed summary. Probably could include a few more pics to.
RocketRollinSX,
That would be perfect, you can email them to me at webmaster@totallyamaha.com, if you dont have the time I can use what you posted too. Thanks
RX1MN Flatlander
Looks good. I installed a guage on my 03 RX Mountain. Am planning to buy a Venture TF and am planning to install a guage before I go for my first run. Had cooling issue on the RX when on hard packed trails. Installed the rear cooler and solved that problem. Can't see how a cooler can be installed on the Venture very easily.
SnowBandit
- Jan 31, 2004
- Maine
- www.slednewengland.com
- 2009 Nytro xtx
I took a 3/4 pipe and just drilled in and soidered the connection onto that.. Of course I do carry an extra hose with me.. Seems to hold... Nice job man... Looks great.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Very nice. Looks really cool. That's something I can actually do, thanks!
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
Also I wired the grounds from the gauge & gauge light to the ground on the headlight plug right next to the gauge.
