TurboKeith
heres an excel file to help you determine what your load % equals in boost. You can edit the vmin and vmax values to match your setup..
http://www.toyzfortrucks.com/rapidbike_load_conversion.xls
Lococoin
- Sep 8, 2007
- Edmonton, Alberta
- www.outlawatvclub.com
Thanks for making this. It would be nice to see Rapidbike change the software so that you can show boost levels instead of %'s. It wouldnt be that hard of a job to do.
Skydog
Help why can not not change the numbers????
Thank you Skydog
Thank you Skydog
TurboKeith
Not sure what your asking. The only numbers to change are highlighted in yellow.
Skydog
I found out my software could only look at the file.
thank you
thank you
- 6K
