Northernboy
After having Code 43 come up on me yesterday while riding, I decided to make up a simple sheet with all the Fault Codes as well as the Diagnostic Codes small enough to fit in a wallet. Just thought I should share it. Now I am going to put a laminated wiring diagram some where. Enjoy.
Nytro RTX Guy
Thanks!
swmpr1
- Nov 20, 2006
I had code 43 twice this weekend in one day. would crank all day long but fuel pump wouldnt run. whats the word on this problem?
Northernboy
Not sure what the word is but mine cleared it's self in about an hour. The nose where the ECU is had alot of snow in it, so I am going to replace the fuel pump relay. I am also going to clean and put in some dielectric grease into as many of the connectors as well. Will seal up the nose better too.
What fixed yours? Did it ever clear?
Skinner
Mines at the dealer now with that problem. Mine wont clear 43. It will start but runs choppy. The dealer called me today and he is still troubleshooting the problem but I will post what he comes up with for a fix when its done.
- 177K
- 16K
