can someone help me with relay info so i can grap some extras when i go by the parts store . an auto parts store will have these right?
ualav8
I'm having relay issues on my 03 rx1. Where are they located? Anybody have pics?
tttario
scubadoo said:can someone help me with relay info so i can grap some extras when i go by the parts store . an auto parts store will have these right?
Just buy them from your dealer. They're $10. They are located above your left foot. There are 4 relays in total. 3 are the same (fuel injection, load, rad fan) and 1 is different (headlights). Normally the fuel injection is the only one that has an issue. It is the closest to the chassis on mine but their loaction varies on each machine for some reason. Good idea to identify it and carry a spare incase it won't start on the trail.
Cheers.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Yamaha was supposed to have updated the relay in 07 but some r still having problems. Rearrange the relays so that the fuel pump relay is on the outside which makes it easier 2 change.
Port Yamaha
RELAY ASSY
8FP-81950-01-00 (replaces 8FP-81950-00-00) $8.27
Port Yamaha
RELAY ASSY
satan660
i have a 08 mtx 350 miles on it and now its been 3 times it dont start becuz of fuel relay....i just turn the key on......hold the relay in my bare hand for a few mins, when u hear the pump kick in and just start the sled...
they just freeze up and stick i geuss
......would be nice to find a relay that would work in the cold
never had issues with my relays,over 4000mi.gunna go buy some just never no when its your day!
bashley
The fuel pump relay and the headlight relay are the same and are right beside each other.
When my fuel relay started going bad I switched the two and the sled started right up and the headlight took about 10 sec. to come on. Went to the dealer and they gave me a new one under warantee. If your warantee is up they are about $10 or less.
tttario
bashley said:The fuel pump relay and the headlight relay are the same and are right beside each other.
The headlight relay is the only one that is different from the other 3 so it wasn't that one. It has 5 terminals instead of 4. You maybe switched it with the load relay that turned your lights on after it warmed up and activated. The headlight relay controls High/Low. Your fuel injection relay has the 4 following wires.
Coil - Red/White, Blue/Red.
Contacts - Red/Green, Red/Blue.
If you are worried about this in the future I would suggest locating this relay and moving it to the outside for easier access if it happens on the trail. Also, carry a spare in your warm pocket and you'll be good to go.
satan660
just hold it in your hand for a few mins it will work it just freezes
