Sledhead_BR
- Sep 20, 2007
- Northern Manitoba
- 2008 Vector LTX GT
1997 VMAX XTC
2005 AC 120
Has anyone had the switch break? Mind did this week and I called my dealer to order a new switch and I have to order the whole front piece which include the hand warmer toggle at about $120 bucks!!
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
What about warranty?
skidooboy
guy on ebay in canada i believe, had sourced the buttons only and was selling them. they were expensive but, not as much as the whole unit. ski
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
Guys, there now are part numbers for the kill switch button & dimmer switch, and they are in stock, I will get them tomorrow for ya, hold tight
Mine broke off and I couldn't be happier! It still works with a fingertip poke, but isn't hanging out to get caught on anymore!
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
part nuumber for the dimmer switch is 8gl-82526-09, part number for the kill switch button is 8gl-86284-09
skidooboy
thanks tj!!!! you the man. ski
Sledhead_BR
- Sep 20, 2007
- Northern Manitoba
1997 VMAX XTC
2005 AC 120
for me it was not just the button that broke on the dimmer switch. a plastic piece broke inside the switch as well which stopped the spring from locking into place between high and low beam. I was stuck in high beam and could not click back into low beam. The dealer told me he can get the button seperatly but anything else inside the switch you had to change the whole assembly.
lancelotlink
I noticed mine fell out as well. Is the button just held by the rubber? If so I may want to order several.
lancelotlink
Anyone have any luck with searching for the parts? I have searched a couple dealers and the numbers don't come up.
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
If you are referring to the parts numbers for the switches / buttons, they are somewhat new so they may not be on/in most dealer sites.
lancelotlink
Ordered one from Port Yamaha. They have them in stock. The dimmer button runs about $6 and the kill button runs about $9.
lancelotlink
Anyone install one yet? I cannot figure out the button is installed. Any pointers?
Ironmanstl
lancelotlink said:Anyone install one yet? I cannot figure out the button is installed. Any pointers?
after you take the main plastic piece off the left housing, unscrew the philips screws on the inside edge of the button housing, pull the part out that was held on by the screws, the button or whats left of it should now pull straight out and you will then see how it is held in there
You may just have a small piece broken off in the switch it self
I just ordered one from Yamaha in Yorkton for $12 cnd. The guy selling them on ebay is a member here and he wants $30 shipped, pretty steep price so you might as well just order one. The above number is the correct one to order the dimmer switch.
