spooled
any one out there running a 3 bar map say 18+ lbs,
TurboKeith
Most of us are running 3-bar map sensors. I need bigger injectors to run it up to 18 psi. Powderlites may have a map made for this.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
X2
The 2 BAR MAP sensor is only good up to 15 lbs. If you want to run higher boost you need the 3 BAR MAP sensor, good up to 30 lbs. I would recommend running the 3 BAR MAP sensor, then you have the opportunity to run any boost you like up to 30 lbs.
Lococoin
- Sep 8, 2007
- Edmonton, Alberta
- www.outlawatvclub.com
What make of 3 bar map sensor are you guys running?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
whalbro??? if I remember it right, get it from Powder Lites, they have it in stock.
www.powderlites.com
www.powderlites.com
spooled
i am running a gm 3 bar sensor, mapped to 20 lbs, with a 1:1 reg set at 38 lbs, but with custom injectors. elevation sea level to 3000. 50 50 fuel.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
I will
- 6K
