powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Stock Apex with 1000 RPM limiter over stock.
Added Timing in bottom end for throttle response.
Big gains in fuel mileage and up to 24 percent pulled out fuel for cruising speeds. set Load Vmin .65 Vmax 3.76
This is great setup so you can upgrade to Turbo or exhaust and get a better price on your turbo kit!
http://www.powderlites.com
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Hey Dave, did you build this with Tuning Bike?
powderlites
- Sep 5, 2005
Apex Stock Map
Built with Tuning Bike for sure No way anyone can build that with a dyno.
Make sure to set up load. steps and Voltage for TPS
I'm gonna download this tomorrow. What do u mean about setting up for load steps and voltage? Thanks!
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
- moncton new-brunswick
Is this good for 06 apex with ram air lid? I already have the pc3usb. Just bought the ignition module.
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
Is this work on my 06 apex pc3ignition module? With ram air mod?
This map is for a RB3 OR RAPID BIKE 3 unless you have a rb3 it will not work sounds like you need power command maps.Is this work on my 06 apex pc3ignition module? With ram air mod?
- 6K
