APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I'm thinking about relocateing a rear suspension on a 2006 APEX RTX to make it a 144 using a 136 skid. Has someone done this and what are the pro/cons. Thanks
welterracer
You dont need to relocate the suspension.. YOu just need rail extensions..
You may need to revalve or respring the shock to make it stiffer as the longer rails should create more leverage..
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Sorry my bad my skid is only a 121 buying rail ext
welterracer
Contact ulmer racing,, I believe he has a conversion kit that has tipped up rails in a 144 version..
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Do you mean buy rail ext to make it a 144
welterracer
Yes..
Ratpack
i just moved a 144 skid back 3.5 inches and put a 151 in. it will have a better angle.
maxdlx
get rail extensions for 136 and set it back 4 inches. It will be a complete different sled n deep snow. Maxdlx
APEX 06
- Apr 30, 2009
- Sheboygan, WI
OK you mave it back 4" but do you have to move it down at all.
Turk
Tech Advisor
I did a set back on my 97 700 mm & it made an unreal difference on how it got on top of snow. it changed the approach angle & my sled just popped on top of snow & stayed up. Good luck on the apex tho. I think it was a mountain performance thingee but it was soooo long ago.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Use a little caution when doing this on a 4-stroke. I have a customer who did this on his FX Nytro (136 extensions + 4" set back) and now it is almost undrideable on the trail due to so much extra front end weight.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Just what to give a update. Relocate the suspension now just need the rails to come in the mail. I used the stock brackets they fit just so looks good I will put some pic up when Im done
maxdlx
lets see the pics
APEX 06
- Apr 30, 2009
- Sheboygan, WI
PICS ALL DONE HOWS IT LOOK
kinger
Did you set the suspension back or just get longer extensions? I woudl be interested in your mount points. What extensions are those?
