rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
If you need to download maps for the FX Nytro, follow the links below. This way we only need one sticky to find downloads related to the FX Nytro
FX Nytro stage 2 map Powder Lites - Author: powderlites - http://www.ty4stroke.com/viewtopic.php?t=62572
Supercharge FX Nytro - Author: powderlites - http://www.ty4stroke.com/viewtopic.php?t=62239
SUPER Charger FX Nytro Stage 3 - Author: powderlites - http://www.ty4stroke.com/viewtopic.php?t=69169
FX Nytro Stock with Hindle Muffler Feb1 - Author: powderlites - http://www.ty4stroke.com/viewtopic.php?t=69404
MPI Supercharger Stage 2 mountain sled - Author: powderlites - http://www.ty4stroke.com/viewtopic.php?t=69324
FX NYTRO STOCK - Author: powderlites - http://www.ty4stroke.com/viewtopic.php?t=69170
FX Nytro Turbo Stage 3 Injection Map - Author: Powderlites - http://www.ty4stroke.com/viewtopic.php?t=70886
New Map S.C. 800Feet 9psi of boost - Author: Skydog - http://www.ty4stroke.com/viewtopic.php?t=70700
Hurricane Nytro 750cc map - Author: Hurricane - http://www.ty4stroke.com/viewtopic.php?t=86714
NEW - FX Nytro stage 2 map Powder Lites - Author: powderlites - http://www.ty4stroke.com/viewtopic.php?t=86848
If a post should be in one of the stickies, please PM me and I'll add it
powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Nytro Stage 2 Nov 26 2010
Nytro stage 2 new map load colums setup with all new settings.
Load voltage 1.75 min 4.8 Max (2 bar map sensor)
Pump corecction 1% 25% sensing 200ms
Notice load % at top of map.
RPM steps are set to make smooth throttle response.
Fuel pressure set at 48 psi
If you have newest project 4.8 at bottom of screen it will have timing control from 1700 RPM for throttle response.
RPM limiter is set up 500 rpm
250-836-4422
powderlites@cablelan.net
We can email maps and send project to upgrade your box.
250-836-4422
lukesju
Does anyone have mapping from AAEN for his header and pipe?
Jacob Sawchuk
- Dec 22, 2015
- Saskatchewan
- 2009 Nytro XTX
Anyone have nytro pcv map for ulmer 240-250 hp turbo
Sent from my LG-H831 using Tapatalk
sshewchuk
- Jul 28, 2013
- Alberta
- Apex
Need a PC3 Hindle full exhaust with air box mod map.
Have you got any solution to your mapping? I have same question, it would be really nice to have some basic map where to start.Anyone have nytro pcv map for ulmer 240-250 hp turbo
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
Thought I would share my autotuned map. Don't know what base map is in there as I bought the sled used and the second owner was not aware of any of these mods except that it was load. Full Hindle exhaust, airbox mod, sled runs smooth no popping etc. The AFR is 13.2 from 2000 to 7000 then goes 12.9 from 7250 to 9500.
