snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
i took off the under side cover and need to know where the drain plug is, i see a round headed torx head on the left side on the motor, is this it? or is it else where, any help would be great thanks
marpolsdofer
Yep, that would be it. There is also one on the oil tank two but that is standered bolt head type.
yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
Very little oil drains out..
xt_gt
how did you get that allen bolt out? i was afraid to snap the darn thing off. i guess there is a screen type thing in the bottom (engine) as well. i just left it alone & did the oil tank.
snopro442
- Dec 10, 2007
- neenah wi.
i took both of the drain plugs out, should i replace the copper gasket or reuse it, i am doing all three sleds and really dont want an oil leak.
Jeremy
xt_gt said:how did you get that allen bolt out? i was afraid to snap the darn thing off. i guess there is a screen type thing in the bottom (engine) as well. i just left it alone & did the oil tank.
Oooh ya, I just drained the tank and not the engine, why worry about engine sludge ???
LOL I had to do that !!!
marpolsdofer
haha good one!
Be carefull if you remove the engine plug, I am left handed and I used an alen wrench and enderd up cuting the top of my and in 2 spots pretty good. Use and alen socket it would work better.
