rx1 man 04
- Oct 4, 2007
- ottawa
- 2007 Yamaha apex gt and 2012 Yamaha apex xtx
i changed the bushing on the helix and secondary sheave, put it all back together and now the belt does not go all the way up to the top of the secondary clutch, I have the spring in the number 6 slot on the helix, I dont see any numbers on the fixed sheave, does it matter which hole the spring goes into on the fixed sheave. any help would be great
70superbee
The holes are marked 1-2-3 in sheave. You have to look close to see the numbers. My 06 attak is a 3-3 setting, but I do not remember what the apex is. Hope this helps some.
Rich
Rich
Turk
Tech Advisor
Apex setting is #6 & #1. The belt won,t sit properly in the secondary unless you run the sled on a stand & let the secondary close on it,s own.
rx1 man 04
- Oct 4, 2007
- ottawa
secondary clutchs setting 6 and 2 or 6 and 1
the manual says 6 and 2 setting , 6 on the helix and 2 on the secondary. I made two marks, one on the helix and one on the fixed sheave before I took them apart. Now cant get them to go together in the 6 and 2 position. If the setting is 6 and 1 that might work. can anyone else confirm the 6 and 1 setting for an 07 apex gt.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I can't confirm the setting, but regardless, either of the settings should work, that's the way it's designed.
Are you twisting the sheaves properly before closing them together? Sometime it can be a bear, it might help with some extra hands.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Must be 6/1 to work well.
rx1 man 04
- Oct 4, 2007
- ottawa
secondary setting
I will give it another shot today. maybe I will get another set of hands to help,
apltx08
Turk said:Apex setting is #6 & #1. The belt won,t sit properly in the secondary unless you run the sled on a stand & let the secondary close on it,s own.
X2...if someone knows clutch set-ups its Turk! he's 1 of the best on this site.
