| View previous topic :: View next topic |
| Author |
Message |
Simons CPR TY Advertiser
Posted: Wed Dec 16, 2009 9:22 pm Post subject: APEX Yamcharger testing by Simons CPR......WOW!!!! |
Simons CPR has begun testing our g force yam charger apex and we are very impressed with what we have seen so far, over the next couple of weeks we will be posting our results. so far we have seen a 20 hp increase at the crankshaft, so where a stock apex is usually around 147-148 horsepower, we are seeing 167-168 hp consistantly on a long hard steady state pull, the powerband is very linear and will be very easy to clutch, i am currently updating my dyno software, and next week we will be continuing our testing with a power commander and exhaust modifications that should further enhance the G Force yamcharger system, after that we will be doing some track dyno evaluation, based on the power we are seeing on the engine dyno, and the power to the track that we all ready see with our simons supertune clutch kit on a stock apex, we should see around a 20 hp increase to the track over a bone stock apex. your talking a 95 track horsepower apex in trail form on pump gas with a very broad power band that cams and head porting will not be able to compete with. simons cpr very is excited to be distributing these kits for g-force because they fill a nitch between the stock apexs and boosted apexs that have previously been an all or nothing solution, when you look at the cost of a supercharger or turbo kit, and compare it to a big bore or cammed and ported apex, there really isn't a huge difference in price, however the turbos and superchargers will make way more power. granted there are problems associated with both, but for those looking for max power the pressurized solutions have been outstanding. now with the g force, yamcharger, you get a direct drive bolt on kit that appears to me will have little to no problems, and produce around 2 pounds of boost, while working well with the stock fuel system, the cost for this system is 2200.00 and is easy to install. we have already seen 20 hp gain, and i feel with a exhaust mod and some timing we will see possibly as much as 25 hp. all of our testing should be finished by the end of next week and we are currently taking orders for the yamchargers now. if anyone has any questions on this kit feel free to call me directly
p.s. I would also like to thank Kevin Boelk for donating his sled for this testing and for all the hard work he has put into helping us test this product. thanks Kevin.
Jeff Simon / Simons CPR
1-414-698-6611
| Back to top |
shanksyamaha TY 4 Stroke Guru
Joined: 27 Aug 2009 Posts: 847 Location: Star Lake NY
Posted: Wed Dec 16, 2009 9:27 pm Post subject: |
Looks very promising. I gotta see it perform on the snow. Then Im in. I'll be buying one soon... _________________ 2006 Yamaha Apex RTX
2008 Yamaha Rhino 700 se in steel blue
2004 Polaris xc 700 sp in blue and white (wifes sled)
2002 Polaris proX 120 (kids sled)
99 F-250 Super Duty Triton V10
LET THOSE WHO RIDE DECIDE!!
THERES NO REPLACEMENT FOR DISPLACEMENT!! |
| Back to top |
ROCKERDAN TY 4 Stroke God
Joined: 08 Oct 2005 Posts: 2326 Location: Niagara Falls NY - Huntsville Ontario(Winter)
Posted: Wed Dec 16, 2009 9:30 pm Post subject: |
Nice work Jeff......cant wait to hear more results with timing and fuel/pc3 ect....
and Great work Kevin!....cant wait to hear some real world trail/lake results!
Dan _________________
PICS CLICK HERE!
-'06 Apex RTX (120+mph)
-'08 Harley CUSTOM V-rod (143+mph)
| Back to top |
Posted: Wed Dec 16, 2009 9:36 pm Post subject: |
| I don't blame you for being skeptical, i was too... but i have been doing this for a long time, i know usable horsepower when i see it, and my engine dyno tells no tales. after the first pull it proved itself to me, the powerband is very wide and tunable, i can't wait to put it on the track dyno, and then up against another apex in a side by side run, its going to be a blast. jeff |
| Back to top |
Posted: Wed Dec 16, 2009 9:40 pm Post subject: |
Is there any way to see if there are any lean spots in the rpm range?? I was kinda worried that the stock fuel system couldn't keep enough fuel in the motor with the boost. I know its running good, and making power but is it causing any unseen wear or stress on the motor due to lean conditions or othewise??? _________________ 2006 Yamaha Apex RTX
| Back to top |
Posted: Wed Dec 16, 2009 9:41 pm Post subject: |
| SIMONS CPR wrote: | | I don't blame you for being skeptical, i was too... but i have been doing this for a long time, i know usable horsepower when i see it, and my engine dyno tells no tales. after the first pull it proved itself to me, the powerband is very wide and tunable, i can't wait to put it on the track dyno, and then up against another apex in a side by side run, its going to be a blast. jeff |
Jeff.....i was thinking since its low boost it might only have good power on the top end RPMS(10,200-10,800)
are you saying on the dyno the HP curve is over stock from the bottom all the way up to top?.....so it will have more Jam in the midrange too?
thanks
PICS CLICK HERE!
| Back to top |
Posted: Wed Dec 16, 2009 9:43 pm Post subject: |
I know on the original turbos they had problems because they didn't have a blow off valve and causing the turbo to stuff the motor with air and fuel when it didn't need it. Is there any type of blow off valve on this system or is it not needed with that low of boost??? _________________ 2006 Yamaha Apex RTX
| Back to top |
Posted: Wed Dec 16, 2009 9:47 pm Post subject: |
| shanksyamaha wrote: | | Is there any way to see if there are any lean spots in the rpm range?? I was kinda worried that the stock fuel system couldn't keep enough fuel in the motor with the boost. I know its running good, and making power but is it causing any unseen wear or stress on the motor due to lean conditions or othewise??? |
we have an air/fuel ratio gauge on it and the stock fuel system appears to be working fine. i don't fore see any engine stress problems either, engine peaks at 10,7-10,800 rpms, torque peaks at 9100 rpms, power curve is very broad with no spikes whatsoever. Jeff |
| Back to top |
Posted: Wed Dec 16, 2009 9:48 pm Post subject: |
| shanksyamaha wrote: | | I know on the original turbos they had problems because they didn't have a blow off valve and causing the turbo to stuff the motor with air and fuel when it didn't need it. Is there any type of blow off valve on this system or is it not needed with that low of boost??? |
NO BOV with this system,and IMO it doesnt need it due to such low boost as you said....
im wondering how much fuel mileage will suffer too...im guessing not too much since its not alot of boost and not adding a whole new fuel map,just works off the pressure in plenum.
gonna be nice to hear real world side by side drag race against stocker....
PICS CLICK HERE!
| Back to top |
Posted: Wed Dec 16, 2009 9:50 pm Post subject: |
| ROCKERDAN wrote: | | SIMONS CPR wrote: | | I don't blame you for being skeptical, i was too... but i have been doing this for a long time, i know usable horsepower when i see it, and my engine dyno tells no tales. after the first pull it proved itself to me, the powerband is very wide and tunable, i can't wait to put it on the track dyno, and then up against another apex in a side by side run, its going to be a blast. jeff |
thanks
Dan |
the bottom end power is about the same, but it just gradually keeps building more and more horsepower on the way to peak rpms, very linear power curve that will be easy to clutch. as for fuel mileage, i think under normal driving it should be close to stock, you will have to add more weight to the clutch for extra horsepower delivered which will reduce cruising rpms at part throttle, which should help fuel mileage. (similar to more overdrive on your car) Jeff
| Back to top |
Posted: Wed Dec 16, 2009 9:52 pm Post subject: |
| ROCKERDAN wrote: | gonna be nice to hear real world side by side drag race against stocker....
Dan |
Thats what I cant wait for. I hope someone has one of these on cranberry lake this year when all the boys are out there and the ski doo trailer is in the lodge parking lot with all the poop talkers... I wanna see how this baby runs down the lake... _________________ 2006 Yamaha Apex RTX
| Back to top |
rxrider Moderator
Joined: 25 Apr 2003 Posts: 5758 Location: Lakselv, Norway - 70N & 25E
Posted: Thu Dec 17, 2009 5:37 am Post subject: |
Great news Jeff :-)
I'm looking forward to read more as your testing continues. Should be something to add to my bone stock Apex. _________________ :-)
rxrider's Turbo Garage - http://www.ty4stroke.com/viewtopic.php?t=47473
2003 RX-1 ER - Custom front mount turbo, Water/Alcohol injection, Fox Floats up front, ZX-2 144" in the rear.
2008 Apex RTX - Bone stock.
Wearing a TekVest when riding. |
| Back to top |
helmic Extreme
Joined: 10 Nov 2008 Posts: 113 Location: Bathurst N.B.
Posted: Thu Dec 17, 2009 6:43 am Post subject: test rune |
Add it out last night for a run on the new snow with the clutch kit for it from gforce sweet!!!! I had a supercharger stage 1 last year with all the bells ans whistle and there is not much difference in the pulling feeling.
You also have the same whistle sound comming out of it as the superchargers.No gauges no tinkering just put 92 octane and go waited a long time for this.I'am not saying that its the same as a supercharger but it sure feels like one at low boost. |
| Back to top |
MrSled Site Admin/CEO
Posted: Thu Dec 17, 2009 7:38 am Post subject: Re: test rune |
| helmic wrote: | Add it out last night for a run on the new snow with the clutch kit for it from gforce sweet!!!! I had a supercharger stage 1 last year with all the bells ans whistle and there is not much difference in the pulling feeling.
Go run it against a stocker and then post those results  _________________
Turning the Competition Blue |
| Back to top |
Posted: Thu Dec 17, 2009 9:38 am Post subject: Re: test rune |
| MrSled wrote: |
Go run it against a stocker and then post those results  |
X2......and then get out the radar gun/GPS and compare to stocker too!
sounding promising!
PICS CLICK HERE!
| Back to top |
