I need help with my sled!!! I bought a MPI supercharge kit for my nytro MTX. Installed it following all directions and now code 13 and 25 are coming up when I turn the key to the on positions. I've went through the directions over and over to make sure I did every step. I've tested and check over this several time and no luck. I went as far as removing the gas tank and all plastices to get access to the trottle and engine compartment on my other sled. I've pulled different wire to see what code they would produce. On ever wire I disconnect when it was reconnected the codes would go away as expected. When I took the GEMS computer incuded in the supercharge kit and connect to the OEM plug on my stock sled codes 13 25 and 84 come up. Then when I reconnected OEM computer without GEMS codes 13 and 25 come up. My thought GEMS is wired incorrect and messed something up with stock computer. Does anyone have any thought on the matter. Please reply.
codes 13 and 25 is intake air pressure sensor ( open or short circuit detected )
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Did you remove the air pressure sensor off the stock air box , plug it back in and zip tie it to the harness to the left of the intercooler?
gsxr
- Feb 24, 2006
- 2023 SRX
code 84 is throttle over ride.
Thanks for all the replies. I know what the codes are I just don't know how to fix them. When I hooked up the gems to my stock nytro I think it did something to the wiring harness or sensors because when I removed it codes 13 and 25 remained. 84 went away. The air pressure sensor is hooked up and working. When it is disconnected code 22 appears. I don't know how to fix the problem. I unhooked the battery hopeing that the computer would reset but it didn't. I don't know if I need to replace the sensors or wiring harness. I was hoping that someone on TY had a fix for this problem. I have $20000.00 in a sled that doesn't work and now a 2nd sled that will start but is sending codes 13 and 25. Please if you have a solution or ideas for me please let me know.
gsxr
- Feb 24, 2006
- 2023 SRX
call Heath at MPI
