secondary clutch 07 apex
green
i need help what are the holes for ? there are 4 in the back and 4 in the front and do you twist the spring. please help i want to learn.
clutch sheave has holes #1 2 and3. helix has holes # 0, 3 6 and 9. ends of spring in holes determines twist degrees. eg. holes 6 and 2 =8 or 80 degrees twist. engage spring in holes and turn clockwise till cam sliders are on buttons, install bolts. most trail clutch setups run 60-80 degrees twist.
