yammi4ever
OK, I read the thread about the top right a-arm bold backing out and thought to myself " I will take a look at that this weekend". Well went for a spin yesterday and when getting back on my sled after opening a gate noticed the right ski was sitting cockeyed. Yep my top bolt was out and a-arm half way out of mounting point.
Called a buddy to come get me and hauled it home. Bolt was bent, (will straighten for now till can get a new one) took a little paint off a-arm and put a he ll of a notch in my spindle from where the upper ball joint was resting on it. Might have tweaked the frame slightly, but won't know till I get it back together (will be calling dealer tomorrow, anyone have the service bulletin number on this)
I guess it could have been worse, as just a few miles earlier i had been ripping along at 75 or so going across a bean field. Don't even want to think of what would have happened if it had fallen out there.
Take a look at this NOW not later, let my procrastination be a lesson to you all.
This is on a 2009 xtx with around 1100 miles by the way.
zeke66
Am I correct or, did I read that this is happening only on 09's?
Time for a couple drops of green Loctite 290.... actually, a little late. Thanks for the warning... might pick up a Nytro.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
I just checked mine this morning, they were not coming out. I was able to tighten down the RH one about 1/2 of a turn though.
Its real easy to check'em, just remove the two phillips screws on the nose cone plastic. Then pull the plastic ahead, and you can fit a 14mm deep socket and rachet in there to see if they are tight.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Mtnviper said:I just checked mine this morning, they were not coming out. I was able to tighten down the RH one about 1/2 of a turn though.
Can you do it with a skid plate on?
yammi4ever
Yeah, It really isn't that big of a job, but I have the accessory bumper and skid plate so it took a little longer, just lazy I guess LOL. I used locktite clean and prime, then a good dose of blue locktite. While I was there I did the other side just for good measure. Book says 32 ft lbs on the torque.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
SledFreak said:Mtnviper said:I just checked mine this morning, they were not coming out. I was able to tighten down the RH one about 1/2 of a turn though.
Yes you can if your only checking them. If you need to remove the bolt, to apply loctite it will have to come off.
just to note, this also happened on my 08, FYI
Mtnviper said:Yes you can if your only checking them. If you need to remove the bolt, to apply loctite it will have to come off.
Can you get small tube down to the nut/bolt end? The Loctite 290 is designed for already assembled parts. It wicks in... good stuff.
http://www.loctite.sg/sea/content_data/93808_290EN.pdf
With that said, it might not be a bad idea to remove the bolt and grease the bushings up, then use good ole' blue Loctite.
yox185
Is there a nut on the back side or does it thread into the frame?
radianguy
- Jan 1, 2007
I checked mine tonight, they were tight.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
yox185 said:Is there a nut on the back side or does it thread into the frame?
It gets threaded into the frame.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
bjowett said:Mtnviper said:Yes you can if your only checking them. If you need to remove the bolt, to apply loctite it will have to come off.
I think if a guy used a small straw, it would work.
yox185
Grimm said:yox185 said:Is there a nut on the back side or does it thread into the frame?
Thanx Grimm. All good here, nice and tight.
Littlehoe
just recieved a recall for my sled because of the a arm bolt... here it is for all to read..
