Apex MPI Stage I and 5psi
shawnmcgr
Calgary, Alberta
I've just picked up a MPI stage I and it's got the pullies needed for 10lbs boost (26/22 I believe). I thought I saw on here somewhere that to get 5lbs max boost all I need to do is swap the gears.
Is that right or can somone tell me the pully combo that results in 5lbs boost?
Thanks,
Shawn.
Thanks alot! Exactly what I was looking for! Looks like I need to clutch it down a bit to keep it below 5lbs.
That saves a few bucks over buying a set of pullies!
SHould be ok if its only 2 years old. But give me a call
thanks
Heath
