ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Just wanted to post up some pics of the new trailer.....originally was to get a Triton but the cost got alittle out of control with all the options i wanted.
This RnR saved me over 4grand from a very similar triton with same options. http://www.rnrtrailers.com/enc_powersport.htm
the guys over at RnR were great to deal with,and there quality is second to none,and the best part is you can buy direct from them,get a quote over the phone quickly for all the options,but many things are standard with RnR.....things like thicker 3/4 plywood(PT) decking,and the widest front Vnose door i have ever seen....making the nose near 6ft!
anyone looking for a nice Vnose trailer check them out...i drove 6 hrs to get it but saved alot of cash and was so worth it....i am very picky about things and i have to say i am very very happy with RnR.
Dan
custom 2 tone black/charcoal & chrome diagonal & rear door stripe
large Vnose front door,62" wide! with near 6 foot Vnose!
custom chrome coving at roof & front Vnose
Custom aluminum Mag wheels(15") & RV style mandoor
finished white interior walls,ceiling and 6 interior lights and switch
standard vents intake and exhaust
custom diamond tread kick plate interior
custom diamond tread kick plate exterior
STAINLESS STEEL CAM BARS
LED lights with spot lights for night loading
Standard Features
* 3/4" PRESSURE TREATED PLYWOOD FLOORS
* 12" TALL PLYWOOD KICKPLATE
* RUBBER TORSION - EASYLUBE AXLES
* ELECTRIC BRAKES ON ALL AXLES
* SPRING ASSISTED RAMP DOORS
* V-NOSE WITH RAMP DOOR ON CURB SIDE
* 2" COUPLERS (2 5/16 ON 24' TRAILERS)
* 15" RADIAL TIRES
* FULL TUBE FLOOR CROSS MEMEBERS
* FULL TUBE ALUMINUM EXTRUSION CONSTRUCTION
* ENCLOSED WIRING
* 6 - INTERIOR LIGHTS
* FLUSH MOUNT EXTERIOR LIGHTS
* D-RING TIE DOWNS
* TONGUE JACK
* SIDE VENTS
* FORCED AIR VENTS
* ATP STONE GUARD
* FACTORY BUILT SIDE DOOR
* ROUNDED ROOF CORNERS AND NOSE
* ALUMINUM FENDERS
* ALUMINUM WELDED ON RAMP DOOR HINGES WITH GREASE FITTINGS
* LAUAN PLYWOOD ROOF LINER
* PLYWOOD FLAPS
* HEAVY DUTY INTERLOCKING RAMP DOORS
* SCREWLESS S-LOCK SIDE METAL
* CHROME HUB CAPS
OTHER OPTIONS
* ALUMINUM WHEELS
* RV SIDE DOOR UPGRADE
* STAINLESS STEEL CAM BARS
* ROOF VENT
* SALEM VENTS
* 12X12 FUEL DOORS
* TWO TONE COLOR PACKAGE
* PLYWOOD WALLS
* ADDITIONAL HEIGHT
* 2 OR 4 PLACE HELMET CABINET
* SPARE TIRE
* SPARE TIRE CARRIER
* WELDED ON STEP
Dan
Standard Features
* 15" RADIAL TIRES
* ENCLOSED WIRING
* D-RING TIE DOWNS
* TONGUE JACK
* SIDE VENTS
* FORCED AIR VENTS
* ATP STONE GUARD
* ALUMINUM FENDERS
* PLYWOOD FLAPS
* CHROME HUB CAPS
OTHER OPTIONS
* ALUMINUM WHEELS
* ROOF VENT
* SALEM VENTS
* 12X12 FUEL DOORS
* PLYWOOD WALLS
* ADDITIONAL HEIGHT
* SPARE TIRE
* WELDED ON STEP
Super Sled
- Feb 25, 2009
- Summit X
Beautiful! Now get some ski guides and a traction mat in there (you run studs, right?) quick before you wreck that nice new decking in there!
Mike
Mike
yamahaboy701
I have used a 2008 R&R trailer multiple times and love it. It is a three place inline and it pulls like a dream. Best bang for your buck!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
mntvipermn said:Beautiful! Now get some ski guides and a traction mat in there (you run studs, right?) quick before you wreck that nice new decking in there!
Mike
i actually just put a new track on the apex ,so i removed my carbides for this trip to my cottage to save that new floor.
i did just buy some matts for the loading ramps and some ski "boots" for under skis...so ill post up more pics of when i get that installed.
i pulled it home from Michigan for about 500+ miles and it pulled so easily with my hemi....even though their frames are much more heavy duty then the triton,the extra weight pulls perfectly...very hi quality.
BTW the powersports models start at 5200 bucks,just cant beat that price for what you get from RnR.
Dan
SledFreak
- Feb 7, 2005
- Ontario. Canada
Dan, So how much for this one out the door with all the options?
SledFreak
- Feb 7, 2005
- Ontario. Canada
All Aluminum?
SharkAttak
Dan, that is mint....i like the in-line trailers, must tow nice.....
schmeg
Nice gouge Dan, just like the handlebar warmer mod,,,,,works for me since it came out! Thanks. Jay
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
SledFreak said:Dan, So how much for this one out the door with all the options?
i had about every possible option added cause their prices are so good and hi quality....this was $6400 US.
with same options a triton prestige was gonna be 11grand!...and triton does not do the chrome diag strip and two tone thru triton was astronomical!
what i like is the quality and heavy duty parts ect they use.
also,they built it in 3 weeks from day i gave them a 500 deposit over phone.....triton was gonna take 9 weeks from november when i originally ordered it.
dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
SledFreak said:All Aluminum?
yes,and heavy duty frame members unlike many i looked at...actually not many companys even make a steel frame trailer anymore,only down south.
dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
SharkAttak said:Dan, that is mint....i like the in-line trailers, must tow nice.....
thanks buddy.....well this is alittle wider then a standard inline of 7 foot...they make this model in a 7.5" which makes a huge difference when loading...i wanted a 7 foot but after researching the 7.5 wide i was sold...the small wheel wells barely take any room,yet still you have a low low loading floor height with tires half underneath deck...the design is really great,and with 15" tires they will last and last.
the LED lights are incredible at night too...and interior lighting(6 lights) all have a main switch when you walk in mandoor or you can use a single switch on each light to turn them on/off individually...just a really great design overall.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
schmeg said:Nice gouge Dan, just like the handlebar warmer mod,,,,,works for me since it came out! Thanks. Jay
thanks!....im loving the new rockmeister heater setup alot...cold pinkies are gone now!
WarriorDan
- Oct 30, 2003
- Bloomfield Hills, MI
- 2022 LT-X GT EPS
I bought a 6 month old used RnR about 5 years ago and it has been great. It is not as fancy as this one but absolutely no problems with it and it tows very easily. I have the three place 7' wide version. When I was looking I could not find anything built as nice for anywhere close to the same price. I would certainly buy another one. I called their support line only once but they went above and beyond to address my issue.
SledFreak
- Feb 7, 2005
- Ontario. Canada
ROCKERDAN said:SledFreak said:Dan, So how much for this one out the door with all the options?
dan
Good deal and nice trailer. I have been looking for a while at trailers and the the R&R seem to be a nice trailer.
grumpysanta
trailer
where did you buy and pick it up ?/
- 11K
