poleclimber
Finally showed up today. Damn things are huge. Was gonna try them out but no carbide kit so I'll have to wait.
Grimm
Carbides on back order?
For sec there, I thought it was April 1st.
Post some pics of the skis if you can, including bottom profile and maybe alongside stock skis.
poleclimber
maxdlx
Man I gotta get a set of those
bashley
Will the skegs from the older ski fit the M9? The bolt pattern looks similar.
Grimm
Wow, a monster of a ski...excellent.
From what I've read, they require a different set of carbides.
low slung
- Feb 16, 2005
If your looking to do speed runs,these are not your skis.But if you want great handling along with good floatation,these are the ticket .
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
WOW!! How much were those a set???
poleclimber
yeah they are a different set of carbides. the holes are just a little off or i would have them on already...no such luck thoughbashley said:Will the skegs from the older ski fit the M9? The bolt pattern looks similar.
maxdlx
got a grinder and a welder I'd make em fit
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
I second that!maxdlx said:got a grinder and a welder I'd make em fit
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Dang, I thought my MTX skis looked like clown shoes, them things are HUGE. I DO have a strange urge to buy a set of them though...............
BombaPolaYama
Ummm, why so much excitement over this new ski?? The bottom profile looks nice and clean and should work ... but the top side looks like a designer gone mad! Why all the ridges, bumps, and hollows for snow/ice to collect and won't those large nubs along the outside cause drag in powder?
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
Aren't these blow molded?
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Yes, they are blow molded and I suspect the top side looks like it does for strength. I am sure they played with the rib structure on the top to get it to look the way they wanted it to.
Poleclimber, what is the max width of these skis again? Is it something like 7 1/4" ???
Thanks, G.B.
Thanks, G.B.
