TY 4 Stroke - Totallyamaha Forum Index
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
MemberlistPosting Rules  MemberlistTY Chat SearchYamaha Parts FinderMemberlistOn-Line Store MemberlistVIP
Log in to check your private messagesActive Topic (24h)  (12h)  Log in to check your private messagesMapMemberlistTY.NET Classifieds Log in to check your private messagesTY Webmail
 MemberlistTY Tech
MemberlistTY Home
MemberlistTY Forum
MemberlistATV Forum
Help = Fault Code 85
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> Phazer General Talk
View previous topic :: View next topic
Author Message
SRX Boy
PostPosted: Sun Dec 12, 2010 7:23 pm    Post subject: Help = Fault Code 85 Reply with quote
I'm getting a code 85 on my '07 Phaser. I know the code relates to the oil pressure sensor and I did recently change the oil. Unfortuantely it was a couple months ago that I changed the oil - I can't recall whether you had to disconnect the oil presure sensor - did I forget to plug it back in??? I did run the machine for a good 5-8min right after I changed the oil and I didn't get a fault code - only got it this weekend when the kids went out for a ride. Any chance the fuse is gone, would be nice if that was the problem rather than having to go back under the air box.
_________________
Current Yamaha Sleds:
2011 Apex XTX
2011 Nytro XTX
2006 Apex ER
2009 Nytro RTX
1988 Bravo 250
Past Yamaha Sleds:
2000 SRX
2007 Phazer GT
1997 Vmax 600 SX
1997 Vmax XT 600
1986 Enticer 340
1985 Enticer 340
1987 Bravo 250
1988 Bravo 250
Back to top
View user's profile Send private message
woolyviper
PostPosted: Sun Dec 12, 2010 8:12 pm    Post subject: Reply with quote
check the plug on top of the dipstick.
_________________
2009 Phazer RTX - 136 Freeride - TracksUSA Extension - Ulmer Clutch Kit - Simmons Gen I Ski's - Fett Bros Fox Float Canister 2's
Back to top
yamahas
Moderator Life
Moderator Life
PostPosted: Sun Dec 12, 2010 8:18 pm    Post subject: Reply with quote
I the plug on top wont throw a code, i think you will need to get under the air box again.
_________________
09 Phazer RTX - Ulmer clutch kit, Slydog powder hounds, 4 Stroke solutions roll over valve, Flotation skid plate, Lake effect pivot riser, Float evol shocks, 121" Freeride, Yamaheater, Vector Secondary Clutch
2001 Arctic Cat ZL 800
Back to top
View user's profile Send private message Send e-mail
SRX Boy
PostPosted: Mon Dec 13, 2010 5:53 am    Post subject: Reply with quote
Plug on dipstick is fine (would be nice if that was the problem) but as "yamahas" noted that won't cause the code. Anyone know if a blown fuse would trip the code?? Otherwise I'm back to tearing it apart again (at least it is wasier than getting to the Apex oil filter etc).
_________________
2011 Apex XTX
2011 Nytro XTX
2006 Apex ER
2009 Nytro RTX
1988 Bravo 250
Past Yamaha Sleds:
2000 SRX
2007 Phazer GT
1997 Vmax 600 SX
1997 Vmax XT 600
1986 Enticer 340
1985 Enticer 340
1987 Bravo 250
1988 Bravo 250
Back to top
yamahas
Moderator Life
Moderator Life
PostPosted: Mon Dec 13, 2010 6:03 am    Post subject: Reply with quote
i guess that in theory a blown fuse could cause the same problem since no fuse and not pluged in could cause the computer to think it was broken since the circut is not complete.
worth a try.
_________________
Back to top
SRX Boy
PostPosted: Mon Dec 13, 2010 8:31 am    Post subject: Reply with quote
Thought that might be the case - anyone know which fuse is associated with the oil pressure switch, I can't seem to find it in the owners manual.
_________________
2011 Apex XTX
2011 Nytro XTX
2006 Apex ER
2009 Nytro RTX
1988 Bravo 250
Past Yamaha Sleds:
2000 SRX
2007 Phazer GT
1997 Vmax 600 SX
1997 Vmax XT 600
1986 Enticer 340
1985 Enticer 340
1987 Bravo 250
1988 Bravo 250
Back to top
UpstateNY_sleds
PostPosted: Mon Dec 13, 2010 8:56 pm    Post subject: Reply with quote
I doubt it is a fuse. couldnt hurt to check though. Mine did that to me last year. I did an oil change and must not have plugged the sensor in all way. took a couple rides and it work itself out. same code.
Back to top
yamahas
Moderator Life
Moderator Life
PostPosted: Mon Dec 13, 2010 8:57 pm    Post subject: Reply with quote
agreed
_________________
Back to top
Jeremy
PostPosted: Tue Dec 14, 2010 8:53 am    Post subject: Reply with quote
It is prob. the little sensor beside the oil filter !!! Maybe nocked it loose or forgot to put it on or not put on all the way !!! You know the one that gets in the way of removing the oil filter !!!
_________________
Blue 08 Phazer RTX
Blue C&A Pros
1.5" Freeride
Schmidt Bros:
Duel pipes
Air pods
Clutch kit
Back to top
ef x eh
PostPosted: Tue Dec 14, 2010 10:59 am    Post subject: Reply with quote
i thought the sensor beside the oil filter was the knock sensor.
_________________
Might as well look good when you ride!
Back to top
lholtzman
PostPosted: Sat Dec 18, 2010 11:45 pm    Post subject: Reply with quote
Yeah, I just had my Yamaha dealer do an oil change on mine. Figured I'd save myself the trouble of doing it myself.
Two days later I have a code 85.
Do I really have to go diggin to find the oil pressure sensor beside the oil filter.
Guess i saved myself no time at all
Anyone have a good description of what I'm looking for
_________________
2008 Phazer MTX
2008 klr 650
2001 Tacoma TRD
1983 ATC 110
Back to top
cannondale27
Moderator Life
Moderator Life
PostPosted: Sun Dec 19, 2010 7:55 am    Post subject: Reply with quote
Here is the pressure sensor.I left it off once and never again.Is one of those things you only forget once.Make sure you tell the dealer what happened.I think a free oil change is in order.
_________________
07Phazer
PCIII,Ulmer bushings/clutch,reverse secondary,Freeride,Axis rearshock,custom rest,all updates done,tunnel fully closed,Pilot 6.9's,UPBushmans bushings,4strokesolutions valve,Dupont Slides
14Viper rtx se
Yamaheater HID lights,Larson Racing 4th Wheel kit,Pilot6.9s,FOX Float Evol X's,Ulmer Clutch kit,4strokesolutions valve
Back to top
lholtzman
PostPosted: Sun Dec 19, 2010 10:08 am    Post subject: Reply with quote
Thanks, that's awesome. I'll let the dealer know. But I think after this I'll just sackup and change my oil. Can't be that hard. I guess I'll know after I go and find the sensor. Thanks everyone for the info. This website rules
_________________
2008 Phazer MTX
2008 klr 650
2001 Tacoma TRD
1983 ATC 110
Back to top
yamahas
Moderator Life
Moderator Life
PostPosted: Sun Dec 19, 2010 11:03 am    Post subject: Reply with quote
It is acctualy fairly easy to get to it. just remore your deadlight, upper plastics and airbox cover. then there are 3 rubber caps on the airbox, take them out and with a long allen key you can unscrew the air box from the sled and there you have it.
_________________
Back to top
lholtzman
PostPosted: Wed Dec 22, 2010 12:19 am    Post subject: Reply with quote
Hey I dug into my sled tonight and fixed the issue, the Yamaha dealer left the oil pressure sensor wire off. I will be changing my own oil from now on.
Thanks for the help everyone Yamaha Rule
_________________
2008 Phazer MTX
2008 klr 650
2001 Tacoma TRD
1983 ATC 110
Back to top
Display posts from previous:
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> Phazer General Talk All times are GMT - 6 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
TY4Stroke brought to you by Totallyamaha.com
This site is not an official site of Yamaha Motor Corp, USA or any other Yamaha entity.
Opinions/comments expressed on this site are not that of Yamaha or any other Yamaha subsidiary or affiliated company.
