ctp1528
I have a 09 apex 350 miles . Ihave the heelklicker 2 speed cultch kit from 08 nytro. Sled is stock 192 its the shootout sled from big moose in old forge. Randy sent me the white spring for prim. I am 6'4 245 without gear.What is a good starting point? Screws to washers any help would be great . IF need be i can give you phone # thankyou in advance .
Turk
Tech Advisor
Do you have a black. I am liking the black hc primary spring.
Try that spring
1 bolt 1 washer in heel
1 bolt 1 washer in tip & fine tune from there.
Try that spring
ctp1528
Dont have a black red ,silver.white will call Randy tomorrow and order one. What kind of rpm do you think ?
Turk
Tech Advisor
10,200ish holeshot climbing to 10,700 or a little higher..
