froines
Thinking about changing the foot rails with after market rails and shortening them up on my 09 mtx. Does anyone have suggestions or photos of what they have done?
yamahaboy701
Here is my build I did last year. Really looked good and worked better.
http://www.ty4stroke.com/viewtopic.php? ... mahaboy701
bradthebest
yamahaboy701 said:Here is my build I did last year. Really looked good and worked better.
i did basically the same thing , it worked great . If i could add one thing i would get a tunnel extension from rat because it turns up like an arctic cat .
froines
That looks great. How did you finish off the tunnel where you cut off the extra running board?
J.Rod
- Feb 21, 2008
- Alberta
- 2008 Turbo Nytro MTX
justinkredible56
I couldn't ever see how the gussets tied into the running board stiffeners. Do you think you would be able to use the gussets with the stock stiffeners?yamahaboy701 said:Here is my build I did last year. Really looked good and worked better.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
The boards look really good!
yamahaboy701
Check out the bottom of page 2. Is that what you are talking about? Not sure if they will work with the stock stiffeners.justinkredible56 said:I couldn't ever see how the gussets tied into the running board stiffeners. Do you think you would be able to use the gussets with the stock stiffeners?yamahaboy701 said:Here is my build I did last year. Really looked good and worked better.
Page 7 and 8 have pictures of the sled finished.froines said:That looks great. How did you finish off the tunnel where you cut off the extra running board?
http://www.ty4stroke.com/viewtopic.php? ... &start=105
justinkredible56
I guess I'm trying to figure out how the gusset ties into the rail stiffeners or running boards. If it rivets into the running board stiffener or if it rivets into the running board itself.
yamahaboy701
justinkredible56 said:I guess I'm trying to figure out how the gusset ties into the rail stiffeners or running boards. If it rivets into the running board stiffener or if it rivets into the running board itself.
Running board stiffener (Running board Trim). Looking over this again I think I tried to put the gusset in the stock running board trim and it would not fit so that would require some more modification. Plus like I said in the build the AC running board trim is a lot stronger then the stock Yamaha trim.
Here is a kit that will work with the stock trim:
http://www.skinzprotectivegear.com/snow ... lkits.html (Go to the bottom of the page)
This was my back up plan / had more money plan:
http://vanamburgonline.com/catalog/prod ... 34b5d387a3
justinkredible56
yamahaboy701 said:justinkredible56 said:I guess I'm trying to figure out how the gusset ties into the rail stiffeners or running boards. If it rivets into the running board stiffener or if it rivets into the running board itself.
Perfect, thanks for the info!
..SNAKEBIT..
