ericparsons
Went to get the nytro ready for winter today and when I turn the key on nothing happens. No click no display no fuel pump noise. Battery is in good condition posts are clean. I installed a new starter relay and it made no difference. I can jump the starter relay and it turns over as it should but will not start. Can't hear the fuel pump run and display does not light up when I jump it. Checked all the connections that were easily accessible mostly the ignition/starter ones. Any ideas?!
Thanks in advance
Sent from my SM-G935W8 using Tapatalk
Thanks in advance
Mathew Masters
Check the kill switch on the handlebar.
Sent from my STV100-3 using Tapatalk
ericparsons
Kill switch and connections checked. That is how it is acting though, just like kill switch is down.
unplug the ignition and check for corrosion in the plug.
Dr. FeeLGooD
I cant remember for sure but I had troubles a year or so after I lengthened my wiring to the gauge pod to accommodate a speedo relocate. I think I had similiar problems. Check those connections and wiring perhaps.
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1985 SRV, 1991 Snosport, 2004 Snowhawk
- Saint Michael
Did you check the fuses on the right side of the sled down by disc brake?
68ozzy
- Jun 2, 2014
- nytro
I have an 09 as well and had an almost the same thing and it ended being a bad battery. Some how the battery post went bad. Local dealer load tested it and was amazed as they had never see anything like it before. I replaced my starter relay prior to battery change and it did nothing as well.
porkchop
^^^^ this.
Full charge + load test the battery.... Today's are crap- 1 bad cell can screw up everything.
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
I had similar issue a few weeks ago when I took my top panel off below the Guage to install my moflow vent. plugged ignition back in and no power. may have had a pin not make contact, unplugged it and blew it out and plugged it back in and worked fine.unplug the ignition and check for corrosion in the plug.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I'd check the battery....
ericparsons
Battery is good
yam429
- Jan 18, 2009
- Saint Michael, MN
- Saint Michael
Did you ever find out what was causing this? Mine is doing the same thing.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
If the battery is good check the connector on the ignition switch harness, and the ignition/starter solenoid. If neither of these pan out corroded ground blocks or critters chewing up wiring in the off season are also possibilities.
yam429
- Jan 18, 2009
- Saint Michael, MN
- Saint Michael
Connections all look good, I had the starter relay tested along with the green 40 amp fuse & they all checked out good. Do you know where all the ground blocks are located? I just replaced the whole front end with a race front end after crashing the sled last year. Finally got it all together and now this.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
If do a search within the Nytro forum there’s several threads explaining where the ground blocks are located.Connections all look good, I had the starter relay tested along with the green 40 amp fuse & they all checked out good. Do you know where all the ground blocks are located? I just replaced the whole front end with a race front end after crashing the sled last year. Finally got it all together and now this.
