Brandon Doering
- May 16, 2019
- Unionville, Virginia
- 2002 Yamaha SRX 700
2008 Yamaha Apex GT
So here we go, measurements from center of driveshaft back to first mounting hole is 8.25”.
Measurement from center of driveshaft back to second mounting hole is 36”. What I ended up doing is dividing the diameter of the apex driveshaft which is l 1/16” and subtracting that from the two measurements so I could measure from the front of the shaft back. I moved the front bracket forward but kept the same height as the drivers on skidoo and Yamaha are basically the same height. The rear I kept the same distance down as stock (Which is 5 1/4” from bottom of tunnel protectors) to keep the ride height the same. I had to make new rear brackets with a 1/8” offset on each because the Rmotion is 1/4” wider than the tunnel in the rear. The front is the same width as stock. I used 1/8” stainless steel for the new brackets. The blind rivets I used I got from McMaster-Caar and cost me about 25$ for 200 rivets compared to Yamahas 2$ a piece. I got a pneumatic rivet gun from harbor freight and it worked awesome. All said and done there is plenty of room between the drivers and the front rails no clearance issues at all. Taking it out for a ride put a smile on my face right away. It just floated but lifted the skis hard every time I hit the throttle. My cousin and uncle were shocked at how it responded and felt. Bumps weren’t even noticeable compared to that aweful mono that was in it. I’ll answer any questions anyone has. Take a look at the pics and I would 100% do this again in a
Brandon Doering
- May 16, 2019
2008 Yamaha Apex GT
No sure why all these pics are sideways. My apologies.
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Looks like quite the project, turned out really nice tho. Just goes to show how much better the Apex could have been without that mono shock suspension.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
That's AWESOME! Keeps us posted on the long term results.
You may have just given me the incentive I need to go R-motion also.
Though I plan on going 128-129 inches instead.
Brandon Doering
- May 16, 2019
2008 Yamaha Apex GT
Definitely, the mono is trash. I was pretty frustrated with how much money you can stick into a mono and it’s still trash.Looks like quite the project, turned out really nice tho. Just goes to show how much better the Apex could have been without that mono shock suspension.
Brandon Doering
- May 16, 2019
2008 Yamaha Apex GT
Do it! You won’t be disappointed.That's AWESOME! Keeps us posted on the long term results.
Macheater
- Feb 7, 2006
- Niles, Ohio
- Niles, Oh
Ya I agree. I even tried the Hygear setup on mine and was still way less than impressed. Ended up going back to an Ohlins 6.1 spring on mine with the Hygear valving. Its about the best (for me) that it's gonna get.Definitely, the mono is trash. I was pretty frustrated with how much money you can stick into a mono and it’s still trash.
So just eyeballing the pics, it looks like the front skid mount is moved forward from stock and the rear is moved reward from stock, with new mounting brackets?
Also, on your measurements, did you go "straight" from one to the other, or was the measurement taken parallel to the ground?
Brandon Doering
- May 16, 2019
2008 Yamaha Apex GT
Yes I moved the stock mount forward based on the skidoo measurements from the center of drive shaft back to first and second mounting holes. The rear bracket I fabbed And had to put an 1/8” offset on each side but I kept it the same distance down from the tunnel protectors as the stock mount. It kept the same ride height as stock.Ya I agree. I even tried the Hygear setup on mine and was still way less than impressed. Ended up going back to an Ohlins 6.1 spring on mine with the Hygear valving. Its about the best (for me) that it's gonna get.
northern srx
Thank you so much for posting this! Please keep us informed on the ride quality as you rack up the miles. This is going to be my upgrade this year in the off season!
Brandon Doering
- May 16, 2019
2008 Yamaha Apex GT
I will for sure!Thank you so much for posting this! Please keep us informed on the ride quality as you rack up the miles. This is going to be my upgrade this year in the off season!
kinger
Awesome job!! Enjoy!
Brandon Doering
- May 16, 2019
2008 Yamaha Apex GT
Thanks man! I’ll update after some hard miles.Awesome job!! Enjoy!
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Brandon, you piss me off!
Now i have to go buy an Apex & rip it apart!
I've actually been thinking of getting a used Ape & doing a complete tear down & re-assemble with new & upgraded stuff.
This project may be the first one i do.
Let us know as the year progresses.
P.S: Nice Job!
P.S2: Thanks for the neck ache
P.S: Nice Job!
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Do you know what year the R-motion is or what model it came off?
Does it feel sprung right?
Meaning, as of now, is there any shock or spring changes you would make?
kinger
Curious if you got any miles? My winder broke down and I used a buddies Doo and the R motion was nice! I bet it will rock in the Apex!
