InRBigness
- Apr 10, 2014
- winnipeg, manitoba
So after many months of waiting my XTX LE came in just in time for me to take it to Colorado to meet up with many of you. Only 7 more sleeps until we leave.
The turbo has been installed, I have put in an Ulmer clutch, Larson Racing 4th wheel kit, HID's from Rock Toyz and a 4 Stroke Solutions Roll over valve. All went in without much hassle.
This sled comes with Fox floats with Evol's all around. My questions are this:
What would the recommended settings for:
a) both the float and the evol's in the front be?
b) Front Skid shock with evol?
c) Rear Skid shock with Evol?
I am about 250 dressed and ride 60/40 Trail. I know that they have to be fine adjusted however I am look for some valid starting pressures.
Couple rules with Evol:
Always inflate Evol first
Evol should always have about 5 psi or more pressure than main chamber. Usually much more.
For fronts I run 95 psi Evol and 60 psi main. Aggressive 145lb rider any more than that in main and suspension did not cycle enough cornering making swaybar useless. This main pressure is 5 psi less than I ran with the stock Float3. So if the guys with XTX without Evols in rear chime in it should get you close. There is also a setup thread in FAQ that should have some specs.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
For your weight start at 130 in the rear. I'm about 240 on the scale.
stingray719
I have been running floats for years, we will get you dialed in right when you get here. Can't wait!!
Happyhours
- Feb 26, 2015
- Oshkosh
- 2016 Viper XTX
2010 Apex
Did you guys come up with some settings on the rear suspension ?
InRBigness
- Apr 10, 2014
I am running 125 in the evol chambers and about 80 in the mains. I weigh about 250 geared up and so far with what I can tell it works well. I run 120 in the evols in the front and about 70 in the mains.
trevorl1
- Mar 14, 2015
- Nova Scotia
- 2014 sr viper xtx-se
I've got a 14 xtx, I know there was a thread that also said which holes were the best to have the rear suspension arms in but I can't find it.
14,15 XTX was the upper holes. 16 lower has been found to work better. There was geometry change.I've got a 14 xtx, I know there was a thread that also said which holes were the best to have the rear suspension arms in but I can't find it.
trevorl1
- Mar 14, 2015
- Nova Scotia
Is that the upper holes in both the front of the skid and rear?14,15 XTX was the upper holes. 16 lower has been found to work better. There was geometry change.
YesIs that the upper holes in both the front of the skid and rear?
johan
So i should use the lower holes on my xtx le 2016
InRBigness
- Apr 10, 2014
You can try it there but mine made a ton of belt slapping on the top of the tunnel until I moved it down.
There is a whole thread on this here somewhere.
http://www.ty4stroke.com/threads/rubbing-sound-at-front-of-skid.138452/page-4#post-1257626
