tedgoesfast
Is there a dyno sheet somewhere on a 07 apex can't find one
tedgoesfast
It gets confusing what is the actual torque number and when does it stasrt getting close to 150 HP at what rpm
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
HP peak on a stock broken in Apex is right in the 10,300-10,700 range at 150 (give or take 1 or 2 hp) with tq around 72-73 lb-ft at that rpm.
A subscription to Dynotech provides a wealth of information on numerous machines including Apex's.
Yammydanny
Good info!! So when changing clutching anywhere in that rpm window? Or is there a more specific rpm you guys are clutching too? What should a well tuned apex in stock form clutching and all rev both while accelerating and fully shifted out? Sorry for all the questions I just got an 07 and wanna make sure it's running properly..thanks
sideshowBob
When you pull the trigger from a dead stop, or even while cruzing, the RPMs should rapidly hit 10200 to 10600 and stay in that range until you let off on the throttle. I have found with my Attak that the sled is slower if you clutch above 10600.
