Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Just look at the edge of the track and see if there are two layers of cords or one.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yeah that’s tough to do. Both my Winder with stock Rip II track and this one look like single ply, and I know one the Winder is a two ply, so wondering what they put stock on this Vector.Just look at the edge of the track and see if there are two layers of cords or one.
I shall compare again, but whereas I keep the tracks edges from fraying with a little heat now and then, they look the same.
RAMSOMAIR
It’s a two ply
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
So this is the Rip 1 without the silent feature in the 2 ply version?It’s a two ply
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Snowgoer older article says they put a Rip II on the 2012 Nytro, but just says Ripsaw for the LTX Vector.
Just on the Woodys Traction site, and after adding sled info it states the size and length, and says Track 2 Ply.
Thanks for the replies guys!
TrueBlue
Got a 2015 Vector LTX that we bought new & now it has only 1600 miles on itHave a Camoplast 8FG-47110-20 on the above mentioned sled. It is the original 1.25” lug track on this 136” track.
Is it a one ply or two ply?
Need to know before I stud my wife’s new used sled with only 2025 miles on it!
CaptCaper
- Jan 1, 2007
- Northern N.H.
Woodys can be wrong. Best call Camoplast and they'll tell you by the numbers off the track. Woody's said mine was 2 ply. It's 1 ply as they checked for me. The head engineer at Camoplast checked also as I questioned the answer from his help. Also looking at the side doesn't always show it as they will tell you. Oh by the way mine is a 1.25 Ripsaw OEM on a 2016 Vector XTX 146 in track.Snowgoer older article says they put a Rip II on the 2012 Nytro, but just says Ripsaw for the LTX Vector.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yes I have done that before. I remember emails and messages did not get my answer! Once I finally got through they were able to look it up!Woodys can be wrong. Best call Camoplast and they'll tell you by the numbers off the track. Woody's said mine was 2 ply. It's 1 ply as they checked for me. The head engineer at Camoplast checked also as I questioned the answer from his help. Also looking at the side doesn't always show it as they will tell you. Oh by the way mine is a 1.25 Ripsaw OEM on a 2016 Vector XTX 146 in track.
That track number that I listed is a Yamaha number! I will take a pic of the other number on the track and see if I can get through to them.
Really wish they would list the ply number on their tracks to make it easy!!
CaptCaper
- Jan 1, 2007
- Northern N.H.
there should be a number for them. Mine was from yamaha oem and I had no trouble with getting info. But LTX Ripsaw were 2 ply on the 136in tracks. I didn a few of them the latest my wifes 2013 Vector LTX . Used Woody's 1.26 Gold Digger's I believe. Best one they had in 1.25. Also you will have to add some protection over the rear cooler or they will hit that.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
The track is a 1.25” lug, so I shall go with the 1.325” Woodys Goldiggers with double backers for a 108 template. Unless of course the track is a 1 ply, then it would be the Grand Masters.there should be a number for them. Mine was from yamaha oem and I had no trouble with getting info. But LTX Ripsaw were 2 ply on the 136in tracks. I didn a few of them the latest my wifes 2013 Vector LTX . Used Woody's 1.26 Gold Digger's I believe. Best one they had in 1.25. Also you will have to add some protection over the rear cooler or they will hit that.
Thanks for the tip on rear cooler protection.
What did you use, over the existing protectors?
CaptCaper
- Jan 1, 2007
- Northern N.H.
Sorry.. been a while but your right. It's a 1.325 stud. That is what Woody's recommended. We've put over 25,000 miles on 3 different 136in track Yamai LTX's with those studs and never had an issue. Used their recommened pattern as well. And in NH we have hard conditions for riding often.The track is a 1.25” lug, so I shall go with the 1.325” Woodys Goldiggers with double backers for a 108 template. Unless of course the track is a 1 ply, then it would be the Grand Masters.
Check this sites sticky's for rear cooler protector installation and issues. Also search the fourm. You'll see it's 100 % needed and not a big job to do on these 136 in machines.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks Capt, I have used the search tool and got the info for rear cooler protecting needed, even with the 2012!Sorry.. been a while but your right. It's a 1.325 stud. That is what Woody's recommended. We've put over 25,000 miles on 3 different 136in track Yamai LTX's with those studs and never had an issue. Used their recommened pattern as well. And in NH we have hard conditions for riding often.
Shall add some hyfax to them. I like the idea of shaping the hyfax to snap over the existing protectors!
We shall see once I start on it!
CaptCaper
- Jan 1, 2007
- Northern N.H.
From what others did over the years it seems you need 1 1/4 in from the fins. A hyfax might just be enough. Back on my 3 Attaks I had to install the cooler and add alot of protection to get the 1 1/2 in I wanted. The newer oem installed cooler has protection but from the fin it isn't 1 1/4 in If I remember so a hyfax on top does that.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Called local Yamaha dealer to ask that question. Is it one or two ply?
Service manager said, I shall have to check some stuff with Yamaha for that answer, so I will call you back!
After checking for me, the answer was, 99% sure that they came from the factory with 2 ply ripsaw!
While studding the track it was noticed that one can see the 2 ply in the track windows!
