rebmo
- Mar 8, 2014
- Rural SE Wisconsin
- 2015 Yamaha RTX-DX blk
2015 Arctic Cat XF 9000 Green (Turbo)
Need Help identifying a couple clips and where they go on a 2015 Viper RT-X-DX.
My Son did the chaincase and exhaust removal for seasonal maintenance this summer and is off at college.
We have the chaincase done and exhaust installed. I have these 2 wire/hose clamp/clips left over.
The top one looks like it goes on the right foot kick plate (haven't put that back in and the screw matches.
I'm not sure on the bottom one. Both would be from the chaincase side of the motor.
Thanks for any help. I don't want to button it up and have a wire or hose get damaged.
snowdust
The top one goes on the top left bolt of the chaincase to hold the wiring that runs that way. The bottom one goes around the oil lines to the lower right of the chaincase and mounts to the frame. I have one apart right now so I can get you pics if needed.
snowdust
rebmo
- Mar 8, 2014
Awesome! Thanks! If you get any other pics while you have it apart greatly appreciated.
rebmo
- Mar 8, 2014
SD, Never mind I clicked on your photo and it shows more and realized it’s located on the shift actuator screw.
Thanks again. Reb
Thanks again. Reb
snowdust
It actually goes on the case. In the pic it would be on the bolt just to the right of it. Do you see where the other one goes?If not I can get a pic of that one for you today.
snowdust
rebmo
- Mar 8, 2014
If no trouble mounted pics would help. As we should have taken before disassembly.
Thanks Reb
Thanks Reb
rebmo
- Mar 8, 2014
Thanks!
- 46K
