12meter joe
Hey guys I just traded my nytro xtx for a left over 15 viper xtx this past weekend. I only was able to put 80 miles on it so far. I didnt even have time to play with the shock psi yet and dont know where theyre at. I will be trying to get things sorted out as im going ridint this weekend.
I was ridding mostly trails and it was like an empty dump truck on 1-2' stutter bumps. I love the sled so far as its very stable and cornners good even with the crap 2" carbide.
Im sure this has been discused so sorry if a re post. What would be a good starting point for all the shocks and straps? Im only 180-185 with gear. I was told theyre set-up stiff from factory? I ride pretty aggressive trail 75% and 25% off so i guess id want to be set-up for mostly trail and sacarfice a little for when im off.
also what carbide combination for the stock tuners?
Thanks for any input.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
what model xtx do you have? I have the LE and run about 70lbs in the front with 120 in the evols and in my skid I run 150/ 200 in both shocks. Seems pretty smooth to me but I am still fine tuning.
12meter joe
It's not an LE. Has fox float 2 in the front and rear. I don't believe the center shock is fox.
zrcrazy
65 in the front... 125 on the back...
12meter joe
Thanks. Where are you at as far as straps and center shock?65 in the front... 125 on the back...
zrcrazy
Stock location for the straps , stock on the center little over half ... Lots of guys attempt turning it all the way down all here
XTX Best Suspension setting in FAQ section
12meter joe
Thanks man I appreciate it!
jpothof
I'm also at 65 in the front and 125 in the rear. 14 threads showing in the front skid shock. Straps tightened one hole down from factory. I run a 4" and 6" shaper bars on the tuners. I'm about 225 dressed. This is the best I've found so far.
12meter joe
Thanks. Are you running the 6" on the insides?
jpothof
Yeah. 6" on the inside. 4" on the outside.
