hughdickerson
- Jan 22, 2023
- Northern Manitoba
- 2021, 2022, 2023 (2x)
Gentlemen,
Aloha! New to the website, I'm bush cruising with four of these beauties - perfect size and power, easy to handle and pull out when you get too pitted in zee POW POW. Anywho, my front frame bumper on my 2021 is loose and I noticed two bolts have rattled there way out on one side that hold the bumper to the frame. I believe they're torq screws/bolts... I can't seem to find a schematic that shows exactly the dimensions/specifications of those screws/bolts. Are they screws/bolts that sink into a threaded female end that's part of the frame or is it a nut & bolt combination? Thanks for your help
Local Manitoban Soggy Swamp Donkey
Have you just looked up the part in a Fische online to see if they are available?
hughdickerson
- Jan 22, 2023
- Northern Manitoba
Yes sir and even the dealer desk was having mad struggles which is why I have found myself here.Have you just looked up the part in a Fische online to see if they are available?
Wish I could be more help. I have so many bolts from Yamaha sleds I am sure I have some.Yes sir and even the dealer desk was having mad struggles which is why I have found myself here.
did you try looking it up on a artic cat fiche as well?
