Daranello
Suspended
Is there a detailed way to do this??? Done it many times on my F7 but this baby's all new to me...thanks
Belts sitting too low right now
Darnello, in your manual on page 56Daranello said:Is there a detailed way to do this??? Done it many times on my F7 but this baby's all new to me...thanks
it shows the spec's. on belt deflection and how it can be adjusted. Good info in that book, I've read it about ten times when things are slow at work. Hope this helps. 1050THMPR
Daranello
Suspended
1050THMPR said:Darnello, in your manual on page 56Daranello said:Is there a detailed way to do this??? Done it many times on my F7 but this baby's all new to me...thanks
Yeah, I see that but it shows you have to remove this small screw on the side of the secondary....the pix and descriptions are not the best in the manual
Thats correct! And on that screw is a spacer. If you look at the picture it shows that the adjusting bolt is on the back side of the clutch, so removing the belt and then removing the secondary will give you full access to the bolt. Measure how high or low your belt is before you remove it to adjust anything. Also if your belt is worn down too much you may not achieve the correct deflection. GOOD LUCK!Daranello said:1050THMPR said:Darnello, in your manual on page 56Daranello said:Is there a detailed way to do this??? Done it many times on my F7 but this baby's all new to me...thanks
dirkdiggler
Suspended
If you want to raise the belt in the secondary you add washers if you want to lower remove washers
WELL PUTdirkdiggler said:If you want to raise the belt in the secondary you add washers if you want to lower remove washers
