SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
So, just figured I'd check chain tension and how to put oil in the chaincase, since I had it serviced at 500 and time for me to do the stuff. The actuator was under pressure, once the bolts were out. I marked everything. The manual says after making sure the insert is engaged correctly, ROTATE 20 DEGREES CLOCKWISE, and in the picture, it (the notch in the insert)is just past the detent, sitting on the radius. The actuator went on exactly one tooth different, and the bolts lined up...no needing to twist it to line them up.
I put it back the way I found it, it works fine, but does it really matter? Who is right?
Thanks.
Thanks.
Thanks.
99% of them are under slight pressure. I put in the reverse actuator gear rotate all the way counter clock wise untill it wont rotate, then pull it out and install with detent to the bottom or 6 o'clock and when you install the spring and puck it will drop right in. Install acutator and it will need slight pressure counter clockwise to get the screws to line up.
As far as whos right, it only matter if its not all the way to one direction to get the detent to hold it so it dont walk out of gear at speed.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Thanks...that sounds like the book. I believe mine is a tooth off..it takes quite a bit of pressure to line up the screws...but that's where Excell set it so I'm leaving it.99% of them are under slight pressure. I put in the reverse actuator gear rotate all the way counter clock wise untill it wont rotate, then pull it out and install with detent to the bottom or 6 o'clock and when you install the spring and puck it will drop right in. Install acutator and it will need slight pressure counter clockwise to get the screws to line up.
Should be fine!!
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
In fact, thinking about that, it seems mine would have a little extra pressure holding the actuator gear toward's the forward direction, or ccw...interesting. I like my old Apex chain case reverse design better..lol99% of them are under slight pressure. I put in the reverse actuator gear rotate all the way counter clock wise untill it wont rotate, then pull it out and install with detent to the bottom or 6 o'clock and when you install the spring and puck it will drop right in. Install acutator and it will need slight pressure counter clockwise to get the screws to line up.
I agree, this thing is a pain in the #*$&@.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Just another reason why so many catI agree, this thing is a pain in the #*$&@.
riders sit at the bar instead of riding their sleds...LOL!
Kidding!
Fast
- Sep 25, 2018
The Yamaha rep said there is a tripple step procedure when setting these up now because several sleds disengaged on the trail last year leaving them no gear just neutral maybe someone knows more about thisThanks...that sounds like the book. I believe mine is a tooth off..it takes quite a bit of pressure to line up the screws...but that's where Excell set it so I'm leaving it.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Since this is how to add oil to the chain case ...if there is a better procedure, it would be nice for the consumer to know.The Yamaha rep said there is a tripple step procedure when setting these up now because several sleds disengaged on the trail last year leaving them no gear just neutral maybe someone knows more about this
The important part is that the detent is in locked position when fully in forward gear. The actuator "Finds" that position no matter how you put it in within reason. That is why it is so important to do the final step of going in and out of forward gear 3 times before moving the sled and then looking to verify the detent is in locked position.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Good info guys....I always just remember, after lining up detent, that the motor needs pressure CC, which makes sense as twisting it CC will ensure the fork is to the left or forward gear.
Taking chaincase apart, and seeing/understanding how it all works(forward/reverse) helps alot when putting it back together.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
True! I was going to wait until after warranty, but there are so many torx screws screaming to be removed!Good info guys....I always just remember, after lining up detent, that the motor needs pressure CC, which makes sense as twisting it CC will ensure the fork is to the left or forward gear.
Nice videos RD....especially the one with the bearing in the brake casting...I like that placement farther away from the snow and water.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Please refrain from swearing since this is a family Forum.
PITA will get the same results.
I'm not sure who can reprimand you but remember "He's checking his list to see who's naughty & nice".
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
People Ingesting Tasty Animals?Please refrain from swearing since this is a family Forum.
In any case, I think he's safe...the term in question is extremely common, and heard often by snowmobiling family members, especially during sled 'routine maintenance'. Many times it is followed by wrench throwing, some muttered words, and a 'what did you say?' by the wife who came out to see what all the clatter was about. It wasn't Santa....
