Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
I modified my Apex battery bracket so that only part of it has to come out for oil filter access. Basically, the bracket comes out, except the top cross-brace and the lower mounting flanges remain bolted to frame. Here's pics for each step:
1. Weld tabs to each side of lower bracket. (red arrow)
2.Drill holes through tabs and bracket on each side.
3. Install M6 nuts and bolts and spot weld each nut. (orange arrow)
Top view - be sure bolts are placed here so not to interfere with battery placement.
3. Weld small tapered angles to the upper crossbrace only. (red arrow)
4. Drill holes through angles and bracket.
5. Install M6 nuts and bolts and spot weld each nut.
6. Remove all four M6 bolts from spot welded nuts.
7. Cut upper crossbrace free from bracket with cut-off wheel. (red arrow)
8. Drill out all 4 spot welds from bracket and remove lower mounting flange.
9. Trim the new tabs on lower mounting flange around the spot welded nuts.
10. Ready for powder coat.
11. Powder coated parts
12. Installed pic of upper cross brace and lower flange. Plenty of oil filter access.
13. Fasten battery bracket with 4 M6 bolts to the 4 spot welded nuts.
Check to make sure there are no parts rubbing anything critical.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
Great job! How much do you charge? LOL!
Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
Well this is just amazing
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Very nice idea.
Just an FYI for those thinking of this mod. The 06-10 apex uses an aluminum bracket so welder will need to be a little more skilled.
vx700xtc
Nice!
Redbeard
- Oct 14, 2011
- IN
...or just buy a steel bracket from you!Just an FYI for those thinking of this mod. The 06-10 apex uses an aluminum bracket so welder will need to be a little more skilled.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Nice work!
philchy
- Jan 3, 2013
- PLOVER, WI
- 2015 SR VIPER RTX-DX, 2008 APEX GT 40TH ANIVERSARY, 2008 VECTOR GT 4OTH ANIVERSARY,2008 VENTURE GT, 2012 VECTOR RS, 2011 VECTOR GT,2003 RX1
Slick, I will be doing this at the end of the season, Thanks for the info.
4Fighter
Clever. Oh-oh, did you just ADD more weight to your Apex - lol
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Best idea I've seen in a long time. Copied your pics! But hey you could make a few bucks doing this. I would make one more bracket to hold the electrical so I never had to disconnect it!
Redbeard
- Oct 14, 2011
- IN
Thanks for the comment, but I have no intentions of making money from this. If sharing an idea helps even one person, then that's enough for me!But hey you could make a few bucks doing this.
sleddog33
I love it! I think I need to make one too.
SRX Boy
Great idea! My knuckles always get cut up ding that part of the job.
Sent from my iPad using Tapatalk
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
Very nice job. 1st thing I did after my first filter change was call Ulmer for one of his filter relocation kits. 1/2 hr oil and filter changes are now a snap.
