crazy canuck
Anyone know if there is an updated driveshaft for the older Apex's that won't shear after 7-8000mi (am running extroverts)?
Also, the dupont sliders wore out in front of the front wheels on the mono (has mega float shock) after a short time... does sucking up front limiters or setting the transfer rod to have more transfer help?
trailhed1
I know regarding the driveshaft issue, that starting in 2008 the driveshaft was updated. For the sliders i can not help you on that.
CaptCaper
- Jan 1, 2007
- Northern N.H.
There is a way to upgrade the drive shafts and I believe there is kit's for that....so search or keep this post alive..someone will help out.
Contact Travis at BOP. He can take a 2010 an up drive shaft and cut it down to fit 06-09. He can also install extro's for you.
Get the marginal snow kit that mounts at the bend in the rail up front. This will stop the hyfax from wearing out there.
http://www.barnofparts.com/Extrovert-Track-Drivers.html
Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
I bought the Anit stab kit from wahl bros and it has the four small wheels that go in place of the cross pipe that your limiter straps go on, and it works awesome.
- 146K
