05rx1204
I'm new to the nytro and when I bought the sled I did look at the shock placement within the a arms. But having no reference point I assumed the sled was good as both shocks were equally uncentered within the a arms. My question is are the shocks supposed to be centered exactly between the A arms? Or are they off center to begin with?
Confused
- Oct 12, 2008
- Mound, MN
- '21 Sidewinder LTX SE
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
Centered
05rx1204
Damn. That sucks. Thanks for the info. Guess I've got some work ahead of me
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
what year nytro?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Mine sit closer to the rear of the arms, both left and right side are identical.
05rx1204
It's a 2010 xtx. I don't have the sled here to measure but I would say each shock is about a 1/2 an inch away from the top a arm on each side.what year nytro?
05rx1204
Mine as well. Getting conflicting info from local snowmobile groups as to whether or not this is normalMine sit closer to the rear of the arms, both left and right side are identical.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Look at the center gusset between the lower a-arm mounts. If it's buckled then the frame has been tweaked.
