Bradford
I just received my new Bergstrom Triple points. Ordered them last Monday and received them this Monday morning in NB Canada so no complaints there! They came with shims and 1/4" ski-savers. My question has to do with the spacers that enable you to widen or narrow your ski stance on the mountain skis. Should I leave them in the center, widen the stance or narrow the stance. I spend 90% of my time on trail. The triple points are 8" and I have a 144" track with 2 studs per paddle down the middle and every 3rd paddle not studded
Brad
Brad
Indy
Re: Bergstrom Triple Points setup on Yamaha Mtn skis 06 RS N
I don't understand how the skisavers can widen a stance. You just put them on under the skegs. Thats it. I would think that you have a good ski setup for trail and some off trail. Why the yammie mountain skis, I thought most riders complained about them not floating.
Bradford said:I just received my new Bergstrom Triple points. Ordered them last Monday and received them this Monday morning in NB Canada so no complaints there! They came with shims and 1/4" ski-savers. My question has to do with the spacers that enable you to widen or narrow your ski stance on the mountain skis. Should I leave them in the center, widen the stance or narrow the stance. I spend 90% of my time on trail. The triple points are 8" and I have a 144" track with 2 studs per paddle down the middle and every 3rd paddle not studded
Brad
Bradford
You missed my point. The "skis" are adjustable enabling you to make the stance wider or narrower. I think a lot of mountain skis are made this wayIndy said:I don't understand how the skisavers can widen a stance. You just put them on under the skegs.
You missed my question. I'm looking for input as to the effect of changing the stance, not how well yammie skis float. However, they do float about 100% better than stock and they steer in the powder about 100% better than the Pilot's that they replacedIndy said:Why the yammie mountain skis, I thought most riders complained about them not floating.
Grimm
Wow, I'm impressed! One week to get them? My experiences has been quite the opposite. Maybe the lack of snow this winter has aftermarket distributors caught up to demand.
If you're a trail rider, there's no harm in widening your ski stance. It should provide better stability and reduce inside ski lift in the corners. With mountain riding, you should narrow the ski stance for tipping the sled over in the powder.
Bradford
Yep, one week. They actually shipped the same day I ordered them...
My thinking is the same as yours so I decided to leave them in the center. Probably the best overall
Brad
Brad
Indy
I had no idea the skis would adjust that way. How is this done?
I had the Pioneer Perf. wide front end kit (a arms) on my sled until one folded last season. The wider the stance the better the RX performed on and off trail.
Indy
Uh Brad, If you ride 90% trail, then I would assume you would want the better handling set up. So I must BE MISSING YOUR POINT, why would you want to leave them in the middle instead of widening your stance.
My Point; of course widening your stance is better for a 90% trail rider.
Bradford
Indy said:Uh Brad, If you ride 90% trail, then I would assume you would want the better handling set up. So I must BE MISSING YOUR POINT, why would you want to leave them in the middle instead of widening your stance.
I guess I should have qualified that statement. Lately, I've been riding trail 90% of the time because of the lack of snow...
