bluegrass
- Mar 6, 2007
how do you check this to see if it is ok I shuck the ski around and don't think there is any play in it is this the right way to check it out
Kirkdking
Jack the sled up and see if the spindle moved up and down might be a little play like 1/32 of an inch any more than that keep an eye in them... I lost mine and the a arm dropped down and started rubbing into the spindle had to replace ball joint and spindle... But instead I baught zbros a arms...
