Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
06 RTX, how much to put in ,
copo427ss
book calls for 8oz. with reverse and 12oz. without reverse. i think i put 10oz. in mine.
bottlerocket
Make sure to check it with the dip stick pushed all the way down.
flambo
Ditto on the 10oz. Works great in my Apex 06 ER.
Sidewinder
- Mar 19, 2005
- Ontario Canada
- Waterloo
Thanks guys all done, I guess I put in 12 oz last year , oooops
apltx08
Sidewinder
- Mar 19, 2005
- Ontario Canada
- Waterloo
OH man I didnt even look at that , its allways the simple things that elude us. haha Thanks again
Yamahammer485
apltx08 said:It says right on your belt cover 250ml/8.5oz and don't try rely on the dip stick its all out of wack, just use a measuring cup and pour it in.
Howcome theyre out of wack?
Iv filled my chaincase up with the oil level mentioned on this site and it was WAY higher than the dipstick. Does this mean by if you go by the guage, your running low?
apltx08
Yamahammer485 said:apltx08 said:It says right on your belt cover 250ml/8.5oz and don't try rely on the dip stick its all out of wack, just use a measuring cup and pour it in.
If you fill to the REVERSE mark on your dip stick on a "REVERSE" model your to low on oil, with 250ml/8.5oz it'll read a tad below the STD mark or very close to it, why is it off I don't know but it should be addressed,this is why I always measure mine in a proper container and pour it in.
Yamahammer485
Thanks!, good to know!
Len Todd
Been running my RX-1 ER with the chain-case oil up to the Std full mark for years. Usually just dump in one of the bottles of chain-case lube. They are 8 oz.
quebec#1
can i put in the synthetic oil that shell sells ?
apltx08
quebec#1 said:can i put in the synthetic oil that shell sells ?
Any good quality that meets YAM'S specs is fine...
tomanytoyz
i always put in my racing gear-oil for boats at 10oz,never any problems.
copo427ss
im running the amsoil marine gear lube. i use it in the atvs too. holds full shear strength with 10% water contamination.tomanytoyz said:i always put in my racing gear-oil for boats at 10oz,never any problems.
