SharkAttak
i'm doing my 500 mi. oil & filter change on my phazer fx and wanted to change out the chain case oil, can someone tell how much to put in the case the attak takes 8.5 oz. is it the same and also is the drain plug in the front or the backside of the tunnel?
gabe7924
This is straight from the service manual:
Recommended oil : Gear oil "GL-3" 75w or 80w
Capacity: 0.25 L (0.22 imp qt, 0.26 US qt)
LazyBastard
Capacity is listed on a sticker on the belt guard, but fill it until the dipstick shows "full". Drain plug is on the chaincase COVER.
SharkAttak
gabe7924 said:This is straight from the service manual:
so that's roughly 8 oz., right?
checkman39
- Sep 2, 2006
yamaha sells the oil in a little bottle, I'm not sure of the size but dump it all in and it should fill you up.
SharkAttak
thanks for the reponse, i'll drain tomorrow start off with 8 oz. and top off from there
Using a kitchen measuring cup, measure what comes out and put that much back in. (Assuming, of course, the oil was up to the proper level in the first place.)
gabe7924
AGAIN, FROM THE MANUAL, .25L IS THE CAPACITY. Go to a conversion website and convert it to whatever you want to.
SharkAttak
gabe7924 said:AGAIN, FROM THE MANUAL, .25L IS THE CAPACITY. Go to a conversion website and convert it to whatever you want to.
7.75 OZ. EXACTLY WENT IN, MOBIL 1 75W-90 FULL SYNTHETIC
BV1
Manual says dont change until 4000 km?
-Steve
-Steve
SharkAttak
BV1 said:Manual says dont change until 4000 km?
-Steve
did the oil & filter change the other day and had everthing ripped apart, why not change gear oil too, can't hurt, adjusted everything and checked out everything so i don't have to worry about it till next fall
GypsyRoots
gabe7924 said:Capacity: 0.25 L (0.22 imp qt, 0.26 US qt)
SharkAttak
GypsyRoots said:gabe7924 said:Capacity: 0.25 L (0.22 imp qt, 0.26 US qt)
you correct, but only took 7.75 oz., i'm sure it would have taken that if i took the cover off
