Changed the chaincase lube in my Apex w/reverse, refilled the case(with synthetic of course), let it sit overnight as to get a true reading.
Checked it and on the "Standard" side it is at the max line, but on the "Reverse" side it shows it is at the second "E", which is higher than the max mark on the standard side!
I know there was a lot of discussion of the fluid capacity on reverse-equipped sleds and those w/o but showing two different levels on the same dipstick has me wondering if I should drain some out to get it in between the reverse level and Standard level.
