Matthew457
I bought my 2012 xtx with around 5000 km on it and have never changed nor had any problems with bearings yet. Thinking maybe now that I’m nearing 14 thousand km I should look into it. Trying to decide if I should just get the dealer to do the job or is it not too bad? Can they be changed with out any special tools? Thanks
speedo bearing for sure unless some one else has been doing it or repacking it. odds are yes to most of them needing replacement but i always do mine every year and usually end up replacing1-2 in the idler wheels.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Sounds like they are due to be done.
You will need a shop press to get the clutch side jack shaft bearing off - and press new bearing on.
Will will likely need a puller, and bearing driver for the chaincase bearings. And there is a bearing in the chainscase cover that needs a puller to pluck it out, and a press to put the new one in.
If you have the tools, its no big deal. But does take some time.
MS
MS
