SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Does anyone know part # for sidewinder yamaha clutch puller? Seems some say, same as the old ones but I want to make sure its right.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
http://www.ebay.com/itm/280613120505?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
maybe not Yamaha but this one works good. used on my sidewinder
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
What size socket?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Not at home... I will post later
Doc Harley
- Oct 17, 2016
- Here & there
ThanksNot at home... I will post later
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
JT I just did mine and it's a 22 mm socket. Mine tightened up quite a bit.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
22 mm that's it! I almost posted before but didn't want to misinform. Thanks uprider
CHECK your offset again after retorque!
uprider800
- Mar 18, 2016
- winneconne wi
I did my offset after retorquing and it was 2 5/16th. So it was within range of the specs.
Doc Harley
- Oct 17, 2016
- Here & there
Thanks Toby!
Offset? How is that checked?
This is getting harder & harder.
uprider800
- Mar 18, 2016
- winneconne wi
Thanks Toby!
Take a straight edge ruler put it in straight till the front of the ruler is in line with the back edge of the primary. Then measure from there to the front edge of the secondary. Mine was 2 5/16.
Doc Harley
- Oct 17, 2016
- Here & there
Got it. Woke from a nap and forgot where I was. Lol.
Can we hydraulic the primary off when needed? Or do we need tools?
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Yes, that is normal for the new sidewinder.I have a play back and fourth on My clutch, like it was on a splined shaft, about 3-5 mm, Is that normal guys?
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
Interesting, out of curiosity, did any of the boosted 2012-2016 cats need the higher torque values as well, to keep the primary clutch from slipping on the crank ?My Advice... retorque the Sidewinder clutches. Mine slipped on the crank a little but it wasn't very tight. It never popped with the pull just came off...
I retorqued it now 106 ft-lbs then 55 ftlbs for the bolt we'll see if that is enough. I'll inspect it again soon.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
I will check my cat and see if it slipped now that is seen 260hp plus.Interesting, out of curiosity, did any of the boosted 2012-2016 cats need the higher torque values as well, to keep the primary clutch from slipping on the crank ?
http://www.turbodynamics.ca
- 46K
