A grinder with a diamond cup on it. Grind it down until the scratches are gone.
You could use some concrete epoxy to fill the scratches but it will look worse than it does now or you could fill in the scratches and then paint or epoxy coat the entire surface.
Believe it or not we seal our concrete shop floor with non toxic RV antifreeze. Basically mop on and let set. It won't fill the scratches but it will seal them. 2 gallons for 20' X 48'
