Nytro77
Okay so I finely decided to take the jump and remove the tunnel protectors off my 2010 Nytro xtx to get rid of the icing issues and to upgrade to a new 2" track. So as carful as I was removing the front tunnel protectors off the cooler (exchanger) I accidently struck the cooler ( circled in pic) with the Dremel....lol bad nerves got the best of me I guess. It looks worse in the pic just curious is this something to be worried about? is there lots of thickness there? I feel its ok and it doesn't leak by no means just looking for a second opinion to make me feel better...lol
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I did this with a ‘stud” years ago and cleaned with alcohol and put a glob of JB weld on it and rode for over 10k miles with out issue.
Nytro77
Did it actually go through your cooler? like was it leaking?I did this with a ‘stud” years ago and cleaned with alcohol and put a glob of JB weld on it and rode for over 10k miles with out issue.
yamadoo
- Jun 3, 2003
Yes it leaked badly before sealed with JB Weld. This is a fairly low pressure system and I put it on thick and never had an issue over several years and as I said over 10k miles after repair.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I wouldn't even worry about that. The coolant runs much deeper in the exchanger. They can take quite a bit of abuse.Okay so I finely decided to take the jump and remove the tunnel protectors off my 2010 Nytro xtx to get rid of the icing issues and to upgrade to a new 2" track. So as carful as I was removing the front tunnel protectors off the cooler (exchanger) I accidently struck the cooler ( circled in pic) with the Dremel....lol bad nerves got the best of me I guess. It looks worse in the pic just curious is this something to be worried about? is there lots of thickness there? I feel its ok and it doesn't leak by no means just looking for a second opinion to make me feel better...lol
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
If you have or can rent a cooling system pressure tester, test the system and see if it leaks. I don't know what pressure our systems run at but typically, most are 15 psi so you could pump it up to that and look for a leak. Alternatively you could run it until it get up to temp and pressure and look for a leak that way.
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
I haven’t seen the cross section of a nytro cooler but most of them don’t have coolant in in the fins. If that’s the case you have nothing to worry about.
- 32K
