Corys
- Feb 6, 2011
I just bought a 2009 Apex RTX. It started shutting down on me, so I would have to shut engine off and restart. I clear the code from the computer, but it came back again. Need help, I don't know if I need to bring it in or if I can fix the problem. Thanks Cory
xt_gt
make sure the throttle cable isn't too tight.
if risers where installed, you may need to reroute the cable or adjust it.
Corys
- Feb 6, 2011
The sled was stock with 540miles, but I will check It seems that it happens if I'm going at a higher speed and then I back off
Cory
Cory
dannyy
- Feb 16, 2011
Do u have turbo ? I had the same problem with my ! I got a wiring diagram and i just "disconected" it ! Ask ur Yamaha dealer and ask for that diagram If u have turbo on it , thats the problem. The engine thinks it have full throtle when u have turbo. Thats becose of the tubro. Sorry for bad english
