Turboflash
- Mar 18, 2019
- Southern MN
Just wondering if anyone has experienced a situation where a 998 has been sitting in storage all summer (since April) and when you go to crank it now (Nov) there seems to be no compression, ie motor "skips" when cranked, like 1 or more cylinders has no compression? Once started, motor seems to run normally. Sled has about 3500 miles on it. Sled was stored with ethanol-free gas with prescribed amount of Seafoam and a tiny bit of 2S oil in gas. Why does it crank like 1 cylinder is low on compression?
stgdz
- Mar 27, 2021
- Buffalo MN
Run it for a few times over a week it will probably be back to normal.
It what mine was like!
Fleecer
- Jun 13, 2014
- 2019 SRX
I had an RX-1 do that years ago. It was like the lifters discharged. The engine cranked like it had no compression. Once started it was normal thereafter.Run it for a few times over a week it will probably be back to normal.
SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
Mine does this occasionally also. It concerned me at first but not now, it always runs fine.Just wondering if anyone has experienced a situation where a 998 has been sitting in storage all summer (since April) and when you go to crank it now (Nov) there seems to be no compression, ie motor "skips" when cranked, like 1 or more cylinders has no compression? Once started, motor seems to run normally. Sled has about 3500 miles on it. Sled was stored with ethanol-free gas with prescribed amount of Seafoam and a tiny bit of 2S oil in gas. Why does it crank like 1 cylinder is low on compression?
It's probably something in the valvetrain that briefly affects compression while sitting.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Rusty valves and seats.
SPM
- Nov 18, 2018
- so. mn
That was my first thought too, but it will happen sporadically during the season also. I thought it was a hydraulic valve train(collapsed lifter)but I see a valve lash setting so I was wrong on that.Rusty valves and seats.
Agree with Mike.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
There's no lifters in these motors. They are a shim under bucket design, meaning that the camshaft is always riding on the bucket and in direct contact with the valve, no way for anything to collapse.
You likely have a corroded valve, run it through several heat cycles and see if it gets any better.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
For a valve to rust - how and where is it stored?
MS
MS
stgdz
- Mar 27, 2021
- Buffalo MN
stop guys you are going to make Tflash tear it all the way down again.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Some areas here in the UP have over a foot of snow on the ground. Put it a national forest rd after dark and run it. (Can't ride during hunting season back after dark its on).
We have close to a foot also. I'm tempted to clean my valves.Some areas here in the UP have over a foot of snow on the ground. Put it a national forest rd after dark and run it. (Can't ride during hunting season back after dark its on).
Turboflash
- Mar 18, 2019
- Southern MN
Customer sled. Putting fiber optic camera into it this weekend. Engine is practically brand new (maybe 1500 miles?)- was completely rebuilt last year due to previous deto (block was stripped, machined, diamond honed; new Corrillo pistons, Carrillo rods; valves lapped and shimming set, new valve seals, all new engine seals, gaskets). Ran flawless last season on Stage 3R 300HP. Stored in heated/AC storage area. Went to start this week and cranked funny. Started but ran erratic for a bit, then sounded normal. Subsequent starts, engine still has a "hitch" while cranking.stop guys you are going to make Tflash tear it all the way down again.
NYTurbo
Valve shim out of place at end of yr last season ?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
I would say it's fuel related, once seafoam and old gas are gone it will be good.Just wondering if anyone has experienced a situation where a 998 has been sitting in storage all summer (since April) and when you go to crank it now (Nov) there seems to be no compression, ie motor "skips" when cranked, like 1 or more cylinders has no compression? Once started, motor seems to run normally. Sled has about 3500 miles on it. Sled was stored with ethanol-free gas with prescribed amount of Seafoam and a tiny bit of 2S oil in gas. Why does it crank like 1 cylinder is low on compression?
