MFC44
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Fox is in my back yard. Rep said yes. I'll be doing this upgrade soon as well.
MFC44
Thanks. I am also wondering how difficult the rebuild is. Easy, moderate, difficult?Fox is in my back yard. Rep said yes. I'll be doing this upgrade soon as well.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
Not something I would want to tackle at home. Let Fox do the mods and re-build.
The Evol add on is pretty easy. Only special tool you need is a aluminum block to hold the shaft. Can be made with1/2in drill bit and a hacksaw. A strap wrench is needed on some to get the air sleeve loose but most your hands can loosen it. You don't really take the shock apart. Just air sleeve. Help is here if needed.
MFC44
Thanks cannondale27 I have a strap wrench I have tools to make block just will need a little help in making it. I am ordering them next payday and will post for some help. Thanks.The Evol add on is pretty easy. Only special tool you need is a aluminum block to hold the shaft. Can be made with1/2in drill bit and a hacksaw. A strap wrench is needed on some to get the air sleeve loose but most your hands can loosen it. You don't really take the shock apart. Just air sleeve. Help is here if needed.
No problem. In mean time look for a piece of aluminum 1/2 in thick minimum and 1in square minimum. Just drill a 1/2 inch hole in it right in center and then cut it in half. This is what you will use to hold the shaft in a vice so you don't ruin the shaft.
MFC44
This block on Ebay 2"x 2" x 7" this should work if I am following you on size needed
That will work. Kinda pricy though. If you go that route drill a 5/8in hole in there too. Part Unlimited carries the blocks also.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Try mcmaster carr
They have plenty of stuff like that
Or even a local machine shop might sell you a piece
- Nov 29, 2009
- sabattus, maine
X2. If you have a small local machine shop they can probably make it for you for about the price of the one you postedTry mcmaster carr
red6rubicon
I used my wifes meat tenderizer worked perfect. Of course she has to buy a new one.
